Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Dell 17" flat screen monitor
It is in power saver mode .I have tried everything it is not the computer my other monitor works on it. The monitor just won't come out of power save mode
  • 2 more comments
  • chingy Apr 02, 2008
    i just installed a new power supply to my pc and i too have the 17' inch Dell flat screen monitor and it is telling me that it is entering power safe mode. How do I get out of it?
  • madater67 Sep 05, 2008
    Every once in a while when I turn on my pc the monitor's Led light goes from green to amber. when I press the buttons on the flatscreen it tells me it is in "Powersave Mode" and to just move the mouse or hit any key or hit the PC's power button? I do this but to no avail. Please help it is very frustrating!!!
  • katrinamack5 Dec 03, 2008
    My computer says it's on power safe mode, everything is hooked up correctly
  • Anonymous Mar 16, 2014
    my hannspree monitor would not turn off in power saver mode
  • 46 Answers
When they stay in power save mode the logic board is usally the problem. Cneck out www.lcdrepair.us they sell all the parts for that unit.
Posted on Jun 21, 2008
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
My monitor keeps going into power save mode
Its not power saver mode, when the display goes black and the power light starts flashing that is a good indication that the power supply is about to die. The Dell E172 monitors are noted for this problem. We have step by step repair guides posted on our web site at: www.ccl-la.com Click on the monitor repair link. The Dell E172 series actually has several sub models, check your specific model, the sticker on the back will have either E172FPb, E172FPc, E172FPf. We have guides for all 3 versions posted.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Jan 28, 2008 | LG Flatron L1710M 17" LCD Monitor
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
400 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
