Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a whirlpool washer and the upper agitator (the one that is supposed to move the clothes down) is not working. What shall I do?
  • 5,911 Answers
You need to replace the agitator dogs. Yes, there is such a thing. This is a very simple repair that should take 30 minutes or less. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are located under the Auger (thats the top portion of the agitator). They are plastic teeth that act as a clutching mechanism for driving the auger during the wash cycle. Over time they simply wear out. The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5.
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Posted on Sep 11, 2009
Testimonial: "Guru, you da man :-)"
UPPER AGITOR DOES NOT WORK WHEN WASHER IS FULL OF CLOTHES
replace the dog ears in the top section of your agitator can get from Repairclinic.com
Mar 01, 2010 | Washing Machines
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My agitator on my whirlpool washer doesn't work properly and that keeps the clothes from getting clean. it seems as something is loose,the bottom part works somewhat but the upper of the agitator's not...
The top portion of the agitator is designed to go in only one direction. The purpose is to keep the clothes moving from top to bottom of the basket. When this "ratchet" action fails to occur, it's due to worn "agitator dogs" (part # 80040) usually caused from overloading. It can be a do it yourself repair, or a very inexpensive service call if a professional is used.
http://www.servicematters.com/docs/part_instruct/285747.pdf
Jun 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The upper agitator on Whirlpool Model LA9100XTW1 is not rotating
To repair agitator remove the top of it < snaps on> then remove bolt from center and the agitator will split in middle. You'll find a center cogg with three arms remove this and replace with new one< the kit that you described is this part > and assemble it.The coggs are move freely to engage so you don't have to align them in any way.
Apr 22, 2009 | Whirlpool Washing Machines
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Agitator
the agitator is supposed to do that in wash dont worry
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
123 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
