Question about Plextor Computers & Internet
I need to know where the plugs go on a px-124tsi external drive. The ones I need are going to the double row of 8 pins. There are 2 plugs with 3 holes and 2 with 3 holes
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Posted on Sep 29, 2008
SOURCE: need wiring help for viewsonic or winfast computer
wiring diagram
Posted on Nov 04, 2008
  • 86 Answers
SOURCE: How to set a Toshiba MK8064GSX hard drive as a
u have to set the jumper to the set of 2 pins that are after the power cable socket
suppose this is the powercable socket 0000 then the jumper will be set to the 2nd row of the folling pins assembly that will be 0000 :[:]:: jumper position -> [ ] look in to the pic and u need to set the jumper on the pins that says slave
Posted on Jul 08, 2009
  • 15 Answers
SOURCE: del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Posted on Sep 30, 2009
Testimonial: "You confirmed the trace out that I had figured and gave me the confidence to jumper and get it working."
Raditronic
  • 196 Answers
SOURCE: i dont have the power plug for my jvc kd-nx5000
check the plug in http://www.metraonline.com/fit.aspx and by by car make.
Posted on Apr 27, 2010
Wiring MSI ms-7641
http://www.msi.com/product/mb/760GM-P34--FX-.html
http://www.msi.com/product/mb/760GM-P34--FX-.html#/?div=Manual
Under the Download subheading click on the blue -
M7641v4.0.zip
Click on the 'country' name nearest yours.
(U.S. is a country, the others Europe and Asia are continents)
A small window will come up -
Opening M7641v4.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the small empty circle to the left of Save File.
Go below in the window, and click on - OK.
A small download window will come up.
Allow the file to download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with zipper on it, and M7641v4.0.zip next to it)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name -
7641v4.0(G52-76411X9)(760GM-P34_760GM-P24_760GM-P2...)
There is your motherboard manual in PDF file form.
(Zip file.
A Zip file is used to send large amounts of information more easily.
It is a Compressed file.
You need to 'unzip' it, or decompress it )
(Adobe Reader uses PDF files)
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
When I refer to a page it is for that page number box.
Clicking on the Zoom In icon at the Top ( + ) Increases the view size.
Clicking on the Zoom Out icon ( - ) Decreases the view size.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires go to, is the Front Panel header.
Example; Front Panel header pinout:
The Front Panel header is two headers on this motherboard.
Go to Page 11.
Here at the Bottom/Right of the motherboard you see the 6 SATA connectors; all of them Black in color.
To the immediate Left of them, and situated Horizontally; is JFP2.
Junction Front Panel 2.
Two rows of pins.
To the immediate left of JFP2 is JFP1.
It is also situated Horizontally.
Two rows of pins.
JFP1 has two rows of contact pins. 4 across the Top, 5 across the Bottom.
The Top row is numbered EVEN. The Bottom row is numbered ODD.
Starting on the LEFT side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side, going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. This is reserved for the factory. Probably a 5 Volt (DC) test point.
D) Pins 2 and 4 are for a Power On LED light, and TWO wire.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
Junction Front Panel 2. (JFP2)
The Top row has 4 pins, and they are numbered EVEN.
The Bottom row has 3 pins, and they are numbered ODD.
Pins 1, 3, and 5. There is NO Pin 7.
A) Pins 1, 3, and 5 are for a THREE wire Power ON LED light.
This type of LED light is a dual color LED.
In the past, and one example; it may have been used for computers that had Turbo Mode, and Normal Mode.
Turbo being Green, Normal being Yellow.
(Which was a bunch of hooey.
Turbo Mode was the Normal mode, and Normal Mode was a slowed down version)
Pin 1 is for the Negative ( - ) wire. Also can be said as the Ground wire.
Pins 2 and 3 are for the power wires, (Positive + ), and each color.
(Example:
Pin 2 for the Yellow side of the dual color LED, and Pin 3 for the Green side of the LED.
Light Emitting Diode. So stating LED -> light is kind of redundant)
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Used to hear BIOS Beep Codes.
If there is something you do not understand, that you need for connecting cables, and peripherals; post back in a Comment.
(A Harddrive, and Optical Drive, are also Peripherals. Not just the Mouse, Keyboard, Printer, Monitor, etc)
Regards,
joecoolvette
Mar 04, 2013 | MSI Computers & Internet
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Nedd pin out for system header on m810dlu
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=4&detailid=203&DetailName=MANUAL&DetailDesc=M810DLU%28V5.2a%29&MenuID=39&LanID=0
Manual.
Click on the country name nearest yours.
Opening 810ds52a.zip comes up on the right in a small window.
Make sure the circle to the left of Save File has a green dot in it.
If not, left-click in the circle to the left of Save File.
Now click on OK.
A small window comes up on the left. Double-click right on the file name 810ds52a.zip
In the next small window go to the left side, and click on Extract all files.
Click on Next, Next, and Finish.
Close the other two small windows, and keep the recent one.
DOUBLE-click right on -> 810Ds52a
(Microsoft Word 97-2003 Docu...
1,353 KB)
As it is a Microsoft Word document, it takes a few seconds for Microsoft Word to load, and the motherboard manual.
[If you don't have Microsoft Office, you can always use OpenOffice for free. MUCH better program than MS Office ]
Page 10 - Mainboard Components
SW1 is the Front Panel header. It is in-between the CMOS battery, and the Floppy Drive cable connector.
Motherboard installed in computer case, SW1 is parallel to the bottom edge of the motherboard, and has two rows of pins.
4 pins across the Top row, 5 pins across the Bottom row.
Pin 1 is on the Bottom row, and is all the way to the Left.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Page 15 - 2: Mainboard Installation
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
C) Pin 9 is reserved for the factory, and N/C. Not Connected.
D) Pins 2 and 4 are for the Power On LED (Light)
F) No Pin 10.
Regards,
joecoolvette
Sep 08, 2012 | PC Chips M810DLU (M810DLUV75C) Motherboard
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
Pins 1, 3, 5, 7, 9, 11, and 13.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
Wiring diagram emachine T5246
OKAY!
There's what I'm talkin' about!
The model number.
The eMachines T5246 Desktop PC uses a
Foxconn/Winfast MCP61PM2MA motherboard.
[You stated Foxconn/Winfast. I got that. Just letting you know ]
Guess what?
So does the Gateway GT5476E Desktop PC,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views - in the list.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
If you need a pinout for the Front Panel header, click on -
S - Front Panel connector
The Top row is numbered EVEN. Starting from the Left side going to the Right;
[Colors going from Left to Right;
Orange/Yellow, Orange, Green, Green ]
Red/Yellow, Red, Blue, Blue, Yellow ]
B) Pins 5 and 7 are a Reset switch, IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. This was used by the factory. It is N/C.
Not Connected.
D) Pins 2 and 4 are for the Power On LED.
If the PWR ON LED is dim when the computer is on, switch the wires around.
Any other connector info you need? Post in a Comment.
Specifications,
http://support.gateway.com/s/PC/R/1009603/1009603sp2.shtml
1) Ram Memory:
Uses DDR2 Sdram at 667Megahertz. (667MHz)
Maximum TOTAL amount for the motherboard is 2GB. (2 GigaByte)
Maximum Amount for each Ram Memory slot is 1GB.
IF, you just have one ram memory module, make SURE it goes in ram memory slot 1. (DIMM 1)
That is the ram memory slot closest to the Processor.
Uses a SATA harddrive, and IDE (PATA) optical drive/s.
Does have two SATA connectors on the motherboard, so it can use ONE SATA optical drive.
On those SATA connectors on the motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rmvr12.shtml
See the bottom SATA connector has SATA 1 next to it?
The SATA harddrive is supposed to be plugged into it.
However, the beauty of SATA is, NO MATTER WHAT SATA connector you plug into, BIOS will find that device.
Want to plug the SATA harddrive into SATA 1? No problem.
Want to plug the SATA optical drive(CD/DVD drive) into SATA 1?
No problem.
Want to plug the SATA harddrive into SATA 2? No problem.
Want to plug the SATA optical drive into SATA 2? No problem.
BIOS will find the device.
For additional questions please post in a Comment.\
Regards,
joecoolvette
Aug 02, 2012 | E-Machines Computers & Internet
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
Starting on the LEFT side coming across to the Right side, Top row;
Starting on the LEFT side coming across to the Right, Bottom row;
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 | Casio Music
Wiring color code sequence for the pins to the front system panel for an asrock p4i65g motherboard. There are 4 double pin connectors. Jim/Sudbury
Can't say what the colours on your case wires are because they do vary but they should be marked up PWR SW (or PWR BTN), HD LED, etc.
Looking at the pin layout there should be a row of four with the pin on the far right missing and underneath a row of five with the last one on the far right being unused.
12 3 4
OOOO
5 6 7 8 9
OOOOO Pins 3 and 4 are PWR. Pins1 and 2 are PWR LED.
5 & 6 are Hard drive and 7&8 are reset
Feb 22, 2009 | Asrock P4i65G Motherboard
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Computers & Internet Logo
19 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
DROPNDEAL
DROPNDEAL
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
