Question about RCA DRC8030N
When I turn it on and put the tv on output 3 the menu will not come up and when it does it looks like a double screen and all fuzzy where you cant read anythin.
    Problem Solver:
  • 10 Answers
I put my tv on av or if you dont have av video channel and use that for dvd vcr etc and it should be clear
Posted on Oct 01, 2009
My playstation 3 is hooked up but the tv screen is fuzzy even the menue screen for it won't come on how can I tell if its on tv or hdmi
Welcome to Fixya. If the screen is Fuzzy it only means that your not on the right Input of the TV. Use the Remote of the tv look for Source, Input or HDMI button and change the input to HDMI.
Thanks for using Fixya.
Feb 07, 2011 | Sony Playstation 3 (PS3) Console
Pizelated output of lcd d40x screen, low brightness, fuzzy looking
change brightness from menu and change exposer level to +1/3 and change your white balance to sunlight
Oct 04, 2010 | Nikon D40x Digital Camera
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Fuzzy picture, can't read the on screem menu to
problem is inside tv,,, a component called as picture tube base is got problem ,,pictube base connects the picture tube to the circuit board inside ur tv..call aservice men to replace it
Mar 18, 2010 | Televison & Video
Channel reset in Menu
Change the tv channel to 4 go into the menu and change it back to 3 then put your TV back to 3
Feb 15, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Ps3 freezes and screen goes fuzzy
Try to restore file system on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
RCA DRC8030N Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
