Question about Craftsman 25cc Gas Line Trimmer
32 cc string trimmer will not run
How to fix a model#358.791510 string trimmer? It will run on half choke but not with choke off. I have checked fuel lines, air filter & carburater screws, also checked screen in muffler.
  • 83 Answers
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Posted on Sep 10, 2009
Will not stay running
How dose it run with choke on Half? I would try adjusting adjusting air fuel mixture, but make sure you have clean air filter in it before any thing else.
Mar 29, 2014 | Ryobi 22 in. 26 cc Gas Hedge Trimmer...
New poulan 2500 wont run well
Sounds like the fuel filter is particularly plugged. Maybe you had a little trash in your gas, or a bit of it was in the tank from manufacturing. Hopefully changing or blowing out the filter will help. That's the first thing I'd check.
Sep 01, 2017 | Poulan 25cc 2-Cycle Gas Powered String...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Jul 13, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Poulan 32 cc string trimmer mod.# ppb100
Try checking the fuel filter, not sure of the exact location but should not be to hard to find. Try looking in the gas tank if it's not readily located. If small 2 cycle engines sit for any length of time ( 30 days or so) with fuel in them the filters can become clogged. If your not going to use it for extended periods or storing it for the winter make sure you drain the fuel tank and run the carburetor dry.
Nov 07, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman 25cc Gas Line Trimmer Logo
548 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
