Question about Panasonic Toughbook 72 Notebook
CF72 Hi I have 5 CF72 motherboards which are all dead, when switched on nothing happens no lights no sound nothing, this seems to be a common problem with the P4 have had several P3 and no problem but there are many out there on e-bay with the same fault, any knowlege of this problem. Thanks Regards Kevin Smith
  • Anonymous Dec 05, 2008
    I have the Problem is that When  i  On my CF72 For a 3 Minutes i automatically Off And i have To Start it Again What do i do?
    Problem Solver:
  • 8 Answers
Have had motherboards become static choked, and all you can do if this is the case is to leave it plugged in to power supply, but turned off, for a day or two. don't know if it works with laptops, but sure works great with "dead" motherboards.
Posted on Jan 02, 2008
Turn key and nothing happens. Car is dead. Lights come on on dash and headlights but car won't start
sounds like your security system failed.. its real common in gm's. I have had the same issue with one of my cars..you can bypass it. this is how I fixed it.. pretty simple.. and I have to say I have had it in my car for 5 years and haven't had an issue since.. hope it helps
Oct 14, 2014 | 2003 Chevrolet TrailBlazer
My imedia b2217 will not boot. Is the motherboard dead? Whenever I switch on the computer nothing happens. No lights, no fans, nothing at all. I have replaced the power supply but still nothing
Hi i'm Basti,
How bout the fan for your power supply, is it running? Try to retrace the cables to motherboard and make sure its tight. Change or use another power supply if possible.
Keep me posted. Hope this helps.
Feb 25, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
I switch on my system and nothing happens The cpu
So practically the pc starts but you don't have any image. Try using another monitor and another video card - one of them is dead.
Jul 03, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
Hi, When I turn on the power switch nothing happens.
remove the RAM & CPU & reinstall them and try
if not, you might be looking at a dead motherboard
Mar 27, 2010 | Asrock K7VM4 Motherboard
Nothing happens when key is turned and clutch is down, no clicking, no lights, battery is fully charged and terminals are tight. 1994 eagle talon fwd 5 speed 1.8L
Sounds to me like the ignition module went out. I would test the ignition module, then I would test the clutch safety switch. If these test out fine I would test the starter and replace it if it is suspected to be bad.
No lights really seems like the battery might be dead, or a fuse is blown. Check the main and alt. fuses.
Dec 26, 2009 | 1994 Eagle Talon
I have an ACER AM5640 and it does not start. I replaced the power supply but still dead. No PST, no lights on keyboard. Nothing.
hi im rain ok it sounds like you may have a dead motherboard. acers are proned to motherboard failure. if the fan nore the led lights in front of your unit
are not working then you most likely have a dead motherboard. make sure all connections are correctly
seated. if so then your motherboard is most likely the problem. also check the power cord to insure that the cord is not the problem. further more try disconnecting the main power source to the motherboard wait 5 minutes to insure there is no ecsess power left in Motherboard. reconnect the main power connector back to motherboard and try booting up. if this fails then *********** board is the problem.
Nov 14, 2009 | Computers & Internet
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
My tom tom 710 is dead the green light is on but nothing on it!
Change the motherboard, green light on and nothing happening is quite common, you can find motherboards on ebay for £22 +p&p.
Its quite easy to do and worth while as the 710 and 910 are still very good units.
Dec 27, 2008 | Tomtom GO 700 GPS Receiver
Car will not turn over dead no sound
It seems as if you have had a major electrical short in a main power circuit, for this to happen.I would take it to a auto electrician and have a test carried out.
Dec 16, 2008 | 1997 Mitsubishi Mirage
Panasonic CF72 motherboards
hi, replace the CMOS lithum battries, or check the smps, if still, then check the voltages on the motherboard regulators.. let me know
Jan 03, 2008 | Panasonic Toughbook 72 Notebook
Open Questions:
Support - Storage Solutions - Toshiba'call +1888784-9316 Toshiba is known to be a world class innovator and high technology product leader globally with its 24x7 major subsidiaries and affiliates worldwide. Toshiba launched their first laptop computer way back in 1985 and since then they have managed a record worldwide cumulative shipment of more than 100 million Laptops at Financial Year 2010. Toshiba laptops are sought after because of its quality and superior performance. Regardless of the superior features and all the convenience, you can easily be denied support by Dell Support for any issues that could mess up with your critical data backup, recovery and security. OS crashes are one of the major reason for critical data loss. The other contributors for data loss are accidental data deletion, Virus Attack and natural disasters. Unless, you have an updated backup, you can very well assume that you may have to part away from your precious data. DataAlign takes control of such situations and helps you Toshiba Support backup your data and restore it as per your requirements. DataAlign lets you select backup schedules and it then runs automatically as per the configured schedules. With Automatic Backup protection, DataAlign gives you peace of mind when it comes to data backup and restore. DataAlign's affordable TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus computer. And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any Toshiba Customer service issue that you may face with your TOSHIBA product. Toshiba Help Desk Number 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 26, 2018 | Dell Computers & Internet
See all Panasonic Toughbook 72 Notebook Questions
Panasonic Toughbook 72 Notebook Logo
131 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
