Question about GE Dryers
Dryer will not shut off keeps running even when turned off
  • 304 Answers
The only thing that can cause your problem is the timer. There is ONE contact in the timer that cuts power to the motor at the off positions.
Posted on Sep 11, 2009
I have a LG dryer model DLE5932W that will not shut off on its own
The cycle timer may be hanging up at the 1-minute point.
Aug 31, 2016 | LG Dryers
DRYER KEEPS RUNNING EVEN WHEN ITS OFF, OPEN THE DOOR IT SHUTS OFF, CLOSE THE DOOR IT STARTS UP AGAIN
Dryer is most likly need to be cleaned out motor is stuck in run mode
may have pile of lint on it check vent if you see exes lint in dryer when taking a part
Nov 30, 2013 | LG Dle5955g Front Load Dryer dle5955g
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
My Kenmore Elite Dryer (Model 110 6095299) keeps turning off even though the clothes are not dry. I have to keep turning the dryer back on, only to have it turn off again. This can happen anywhere...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There a few other things that can shut it off also...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore 63942 Dryer
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Automatic dish Dryer will not shut off, cooked some plastic dishes
my best advice at this time is do not turn the breaker back on this unit i have been looking at the wiring on this unit and what your saying is happing should in no way be happing i really need your serial to see if its one of the units affected by the recall
Jan 22, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Dryers Logo
83 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
