Question about Sanyo Televison & Video
Sanyo vcr player vwm 900, tape won't COME OUT.
    President:
  • 1,653 Answers
This needs a little bit of care but essentially you will need to unplug the power from the VCR then do the following:
Remove the top cover
Then with the front of the VCR facing you look to see if any of the tape is wound around a large metallic silver drum, that is tilted upward and is not flat, at the rear of the tape casing. If so then it means that it has wound around the drum and you will need to retrieve the tape to allow the eject mechanism to work. Do not touch the shiny polished part of the drum. To get the tape in usually means that you have to locate a plastic or metal cog wheel, usually on the right side of the VCR that you can turn with your finger. This makes the VCR motor move. Also there is one that works the tape eject mechanism. If you can find the one to wind in the tape before working on the one for the tape eject than you stand a chance of rescuing the tape, if not then it will get some damage. Don’t worry about turning the cog wheels with your finger as you can do very little harm to the VCR with no tools involved and no power on. Moving the cogs this way will only cause very small movements with the tape motor and eject so you will need to be a little patient and you will soon see what is happening. Once remove run a cleaning tape through the VCR before you use it again. With the limited space available her it is difficult to give you much more info.
Posted on Sep 11, 2009
I have a Sanyo VWM-900 VHS player. I need a belt to replace a broken one. Do you know where I can find one to buy?
electronic parts shops ( Jaycar or the like ) sell assorted belts for various makes of vcr units
try e-bay and search for vcr drive belts
Sep 30, 2016 | Sanyo VWM-900 VHS VCR
Need a owners manual for a Sanyo vcr vwm 800
Here is the manual for the next model up. It should be similar enough to fix your problem. I hope this helps. http://www.retrevo.com/support/Sanyo-VWM-900-VCRs-manual/id/311ag907/t/2/
Mar 15, 2011 | Sanyo VWM-800 VHS VCR
I lost my sanyo remote for vwm950 vcr
Buy a universal remote (Wal-Mart) and enter the code for Sanyo VCR. You should get all the major functions of the original remote.
Aug 22, 2010 | Sanyo VWM-900 VHS VCR
Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Mar 10, 2010 | Sanyo VWM-800 VHS VCR
My sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Mar 22, 2009 | Sanyo Televison & Video
Had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
Dec 04, 2008 | Sanyo VWM-950 VHS VCR
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
SANYO VCR VWM-900 playback is jerky
Your post/description indicates that possibly the brake mechanism of the supply reel is acting up. A typical VCR has 2 reels inside that spins the tape. The left side is the supply while the right is the take up. If the brake (on the left/supply) is engaged (even partially), then the entire mechanism would have a hard time pulling the tape around the video/audio head and would partially be stretching. This would represent itself as jerky audio/video in most instances. There would possible also be a low screeching sound coming from the machine/tape. An indicator would be stretched tape - there would be uneven edges of the tape.
Since this is an electro-mechanical problem, perhaps your best course of action is to seek the services of a qualified video machine technician.
Alternately, it may be possible to loosen things up by first fast forwarding the entire tape and thereafter rewinding fully before you play it.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
Televison & Video Logo
174 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
