Question about 2wire (1000-000057-000) Modem
My 2Wire Modem stopped broadcasting a signal
SSID is enabled, Channel is on 6. No idea what caused this? The wireless light on the modem isn't on.
  • 22 Answers
TYPE "HOME" ON YOUR BROWSER (WITHOUT THE QUOTES) AND CHECK IF THE WIRELESS FUNCTION IS DISABLED.
Posted on Sep 11, 2009
Netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
My modem will not give a signal even though it is hooked up write
log on to the modem setup page using the default gate and check if Broadcast SSID is checked
May 31, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
My wireless has stopped working in general
You should consult a vetenary doctor........
Apr 28, 2009 | 2wire (1000-000057-000) Modem
2wire modem is not brodcasting wireless
Usually 2WIRE modems are automatically configured to broadcast wireless. If your modem is not broadcasting it can be due to a few minor D.I.Y issue.
1. Access your gateway address E.g 192.168.1.254 in most cases
, access wireless settings, scroll down to see if the ENABLE SSID is checked. If it is not checked, check it and submit settings. Try searching for wireless again and it should appear in your wireless networks
2. Check your wireless channel if its in the default channel. By default it should be in channel 6. Too high channel will not broadbast wireless networks. E.G Channel 13 will not broadcast wireless. Even it does the wireless will not be strong enough.
Hope this may help and solve your problem
Jan 14, 2009 | 2wire (1000-000057-000) Modem
2wire wireless router/modem
there is only one quick way to turn off your wireless internet access.
Turn off the modem or router if you are using it.
For your information, all home networks have their own access key, without which nobody can access it... it is normally printed at the bottom of the modem. 10 digit encryption key.
Was I helpful enough??
Nov 07, 2008 | 2wire (1000-000057-000) Modem
WIRELESS ISSUES
there are few options to test
Option 1) Check if the SSID and WEP key in the modem page
tally with your logon SSID or WEP key, because
limited connectivity issue happens when SSID and
WEP does not match
Option 2) Restart your modem
Option 3) Check wirings on telephone line , replace tephone line
with another telephone line and make sure the socket
plugged in from the telephone line is a BB tel number
and service has been paid promptly every month
Option 4) Change the wireless channel in the modem page to
detect the wireless device from 9-11 at 192.168.1.254
address in Internet explorer
Option 5) Bring laptop closer to the modem and ensure wireless
led on the modem is lighted and the wireless led from
the Laptop is enabled
Jul 23, 2008 | Computers & Internet
2wire 1000sw modem
Make sure you have your cords plugged into the right plug-in and that all your cords are very sucure, I am sure you havve done this but i have been throug the same peoblem before. it could be a number of things;
GOOD LUCK!
TINA
Feb 23, 2008 | 2wire (1000-000057-000) Modem
2wire (1000-000057-000) Modem Logo
344 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
