i always use a hair dryer just dont melt anything by getting too close. if the water line is freezing, most likely the valve that lets the water in is leaking thru just a little. this very small trickle is moving slowly enough that it has time to freeze. i would replace the valve. if it happens again you will have to put a water filter in the line because gunk in the water is making it stick part way open.
turn off the frige completly then let it unfreze for 1day or 2 and turn water off then turn back on and water should work,if my info was of any help please leave a comment,vote,note.thankyou
I Have a Kitchen aid superba side by side with the water filter in the bottom. Water comes to the...
(More)
I Have a Kitchen aid superba side by side with the water filter in the bottom. Water comes to the cold water outlet but not to the ice maker. I changed the filter but it did not help. The green light outside is on but the red light inside close to the on/off switch is blinking. The switch is on.
Ice is dispensng but water is not. Have never changed filter. Could that be part of the problem....
(More)
Ice is dispensng but water is not. Have never changed filter. Could that be part of the problem. Can't get the filter off.
The refrigerator stoped cooling at night, lowered the tempeture setting still wont cool what could...
(More)
The refrigerator stoped cooling at night, lowered the tempeture setting still wont cool what could be the problem
