LCD RCA quality issue with V.Smile
Grainy picture quality on just the RCA input with a V.SMile on a LCD TV.
  • Anonymous Jan 31, 2009
    When V Smile is connected to LCD TV, the picture keeps jumping. No problem with old cathode ray TV.
    Do I need to change any TV settings?
    SAmsung 40 inch LCD
  • aisberg May 10, 2009
    can't change vertical or horizontal solution on my 40'' LCD TV for the V.Smile output signal. No problems with other video sources.
No picture or sound on TV with V-Smile. Could the wires be replaced on the V-Smile?
Posted on Oct 25, 2008
I have an Audiovox FPE3205 that the picture doesn't hold the clarity and gets blurry and grainy. Support said that it needed to be reset, but I've done that and still the same issue
I do not want to type the answer to this problem because I do not like to be the bearer of possible bad news. This television having been manufactured around 2006 may have reached the end of its life. As years go by, the picture quality on all LCD televisions diminishes.
Ok, ok, I got that out of the way first. Now forget that I just said all of that for a moment. This television will display a 720p resolution from its component input (green, blue, red, white, red). Make sure that whatever is connected to that input is only set to display images at a 1080i or 720p resolution. A wii or a regular dvd player not a bluray should look ok on the composite/RCA input. I'm not recommending the S-Video input for anything, and of course a computer can be connected to the VGA input still.
If the television looks bad even when displaying content on that 720p input then service can be considered and boards changed if you want to put money into this television rather than purchasing another one.
Oct 08, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
I want to pluge a v smile on my tv
You need to use the composite (Red, White, Yellow) connections that come with the Vtech. Once connected you will probably need to change your TV to use the 'EXTERNAL' input source.
Mar 01, 2011 | Vtech V.Smile TV Learning System
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
the easiest way is to connect it to your tv. you should have some red,white,and yellow input ports in the front or the back of your tv set. match the color code and have fun:)
Feb 05, 2009 | Vtech V.Smile TV Learning System
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Game will not start
Turn the cartridge the other way and try pushing it in with the game name facing towards you. This should work.
Dec 29, 2008 | Vtech V.Smile TV Learning System
1 Answer console - picture jumping up and down on 37" LCD screen
I found this with ours and I bought a new system and the AC adapter to go with the new system batteries were getting crazy anyhow the kids hooked up the old one to the vsmile adapter and it stopped. So from experience you need fresh batteries or only the vsmile 9v adapter, other brand adapters also caused the jumping!
Dec 26, 2008 | V.Smile V Smile Console
V tech smile.
It sounds like you need a new cable that runs from the unit to the TV. Check the cable for cuts, etc.
My kids damaged mine closing the entertainment center door on it. I cut the wire, reconnected the wires all and taped it back up. Works fine now :D
Dec 05, 2008 | Vtech V.Smile TV Learning System
Using v -smile on symphonic tv
go below Ch2, you may see L2 and L1 before it goes to ch132 or highest tuner channel.
Mar 03, 2008 | Symphonic WF20D4 TV
Televison & Video Logo
452 people viewed this question
Top Televison & Video Experts
