Question about Pioneer VSX-D914 Receiver
DVD video stops; audio continues
My 2 year old D914 worked fine until one day the video feed to the TV stopped while the audio continued normally. When I disconnected the power for a few minutes the problem stopped. Gradually the power down period needed to be extended to many hours, and the time until the video stopped was reduced from 30 minutes to about 5 minutes. The audio was never interrupted.
    Problem Solver:
  • 13 Answers
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Posted on Dec 20, 2007
I have a 10 year old Sharp LC-46D62U flat screen tv. The power light continuously blinks green as soon as the power cord is plugged in. There is no video or audio.
TV set power supplies are subject to failure of large capacitors in the power supply which only have a shelf life of about 10 years so your power supply has likely failed. Unfortunately the cost of new TVs these days Baker's such that it's not worth repairing. And there is no simple fix that I know of. I have personally recycled hundreds of these TVs with the similar issues and indication. If you're really serious about it, you can look for a replacement power supply on eBay for the same model. If you have technical abilities than replacing the capacitors would likely fix the power supply. The capacitors are not very expensive but you need to have some technical skills. Any capacitor that has leakage or a raised top even a slight amount is likely bad. Jenna Lee for a repair we replace all the caps. Good luck
Jan 09, 2018 | Sharp Televison & Video
What needs to be done to repair it?
The error code that you listed indicates that the unit is shutting down due to the temp sensor triggering a fault. Most likely, there is bad connections on the temp sensor itself that will need to be resoldered.
Jul 29, 2015 | Yamaha RX-V663 Receiver
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
My RX V640 is 5 years old..no problems...no changes to the configuration. when I use to the DTV/Cable setting HDTV..video feed...stereo sound etc is fine. Lately when I try the DVD setting to record TV to...
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
Aug 19, 2009 | Yamaha RX-V640 6.1 Channels Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Pioneer VSX-D914 Receiver Logo
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
