Question about Friedrich D65B Dehumidifier
D50A DOESN'T SEEM TO BE GATHERING MOISTURE I HAVE IT SET AT 70% HAD IT ON FOR SEVERAL DAYS NOW AND THE CONTAINER REMAINS EMPTY
    Problem Solver:
  • 11 Answers
Your setting is to high. Try to set it as low as possible
Posted on Sep 13, 2009
There is no water going in the container can you Tell me why this is
some reasons i can think of are
(1) operator not famliar with operation of dehumidifier , Ie controls not set properly or interlocks not made on bucket full switch , just because you hear a fan running doesnt mean it's working
(2) unit defective , or etrreemly dirty inside filters never cleaned in its lifetime
(3) operator askin machine to remove too much moisture from air than it can so now room has no excess moisture to "give up" settings less than 53% rh could cause this problem , this of course is precusor to unit works very well at first then sort of tails off days later
Feb 11, 2015 | Dehumidifiers
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
Hope this helped you.
May 10, 2011 | LG LHD45EL Dehumidifier
The dehumidifier cuts off when it is set on 70% as soon as the compressor cuts on. i can leave it on lo and it runs.
If you're setting the humidity level on 70 % , that means you want to leave the relative humidity in the house at 70%. That's why the dehumidifier is cutting off. Your house is already at 70% humidity or higher. If you want to remove humidity, set the level lower. If your trying to make it cooler in the house or remove a lot of moisture, set it a 35 to 45%.
Hope this helped solve your problem.
Apr 16, 2011 | Kenmore Dehumidifiers
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
No water filling in tank (whirlpool Gold AD70USS 70 Pint Per Day)
the unit has a sealed system leak that need to be repaired by sears 1-800-905-9505 for service
Apr 13, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
Friedrich D65B Dehumidifier Logo
77 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
