Question about HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet K80 copying/faxing faded.
My HP OfficeJet K80 has stopped copying and faxing properly. The output is so faded that it is unreadable. However, the printing quality is fine. Any suggestions as to what the problem might be?
5 Suggested Answers
  • 3587 Answers
SOURCE: OfficeJet K80 All In One
did you remove the old driver first? sometimes that's needed
Posted on Mar 22, 2008
  • 85 Answers
SOURCE: poor quality output
Hi If your printer has been left unused for a while your print head is clogged.
You need to unclog it with a print head cleaning kit like Magic Inkjet Flush or if in a rush give it the Magic sauna treatment.
Heres how:
1. Remove print head
2. Hold print head directly in escaping steam from a kettle for 5/10 seconds only
3. Wait 5 seconds and sit it print head down onto a paper towel untill you get an inky foot print.
4. Print test.
5. If any white lines repeat above.
6. Also try wrapping in a paper towel and FLICK DOWNWARDS to put fresh ink into print head after steaming.
Good Luck!
Tinteiros (Ebay)
Posted on May 30, 2008
  • 566 Answers
SOURCE: cant receive fax's only can send
Check this troubleshooting page from HP Support:
HP All-in-One or Fax Product - Troubleshooting Fax Transmission and Reception Issues
Posted on Jul 15, 2009
  • 76 Answers
SOURCE: HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Posted on Jul 21, 2010
  • 125 Answers
SOURCE: Can I reprint an incoming
If the printer doesn't have memory function itself... they're not going to reprint.
However, for your HP6310, they do have a function for 100 pages of fax memory.
Fo go fax manu (on your left side, by facing printer), press the fax set up and will see the reprint for fax.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Posted on May 02, 2011
0 characters
1 Points
Making a simple copy comes out blank. color copies normal. changed black cartridge and still blank. faxes fine and prints from pc fine
Depending on your Operating System, you can try the fixes listed here.
Please keep me updated, we will proceed as soon as you try the fixes listed on the link.
Hope it works for you.
Sep 21, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
Hp office jet K80 recieves fax, sounds like it is printing but pages are blank
It sounds like an empty cartridge. check your cartridges, it may be time to replace them. You have to give more information like did you try a print test and if so did it print ok? have you tried to have someone send you a test fax from different numbers?
Jul 17, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
HP K80 paper jamming during fax
Did not resolve issue, but was looking for free advice at the time. Will look in to your product later.
Sep 16, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
K80 all in one
our problem is similar and we've posted it....We have one land line with fax over facility. The fax is assigned a different phone number to the telephone line. The fax number rings different to the telephone ring but both are 'two rings' and the fax machine cannot differenciate between the two and keeps answering the telephone. The k80 has a maximum of 6 rings before it answers and this is too few to allow us to get to the phne in time. Also we have an answering machine on the telephone line. How do we get the fax to answer only the ring from the fax over line?
is it the same prob? Cowboy has posted some suggestions.
Good luck
Apr 24, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
K80 OfficeJet has trouble distinguishing fax and phone ring tones
I would suggest getting a new one, but BE SURE you check to see if it will work with VoIP. I have the HP 6210 and it has problems with VoIP as well. Go to a place where you can test it at home and be sure you can return it if it has issues. Best Buy, or Staples are pretty good with returns, but SAVE the receipt! LOL... Sorry I couldn't offer better news! //Don
Mar 22, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Cannot get thefax function to work
You can get a User Guide(Basic Guide) from the following link: HP also has an online Guide if your prefer at: Hope that helps, Regards, Armando
Apr 26, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
236 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
