Find the value of the variable ''x'' 6x+6=4x+12
  • yadayada
    yadayada May 11, 2010
    for what reason??
    Scholar:
  • 86 Answers
6x+6=4x+12
6x=4x+6
2x=6
x=3
Posted on Sep 10, 2009
    Brigadier General:
  • 8,619 Answers
Answer is X=3.
  • 746 Answers
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides.
6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x.
2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides.
2x=-6+12
Add 12 to -6 to get 6.
2x=6
Divide each term in the equation by 2.
(2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors.
x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term.
x=3
Good Luck
  • Shahzad  Waseem Akbar
    Shahzad Waseem Akbar Sep 10, 2009
    6x+6=4x+12
    6x+6-4x=12
    2x+6=12
    2x=-6+12
    2x=6
    (2x)/(2)=(6)/(2)
    x=(6)/(2)
    x=3
    Good Luck
I need to understand how to divide a binomial.
Let's take 2x^2 - 10x +12 and divide it by x-2.
__2x_-_6____________
x-2 ) 2x^2 - 10x + 12
2x^2 - 4x
- 6x + 12
- 6x + 12
0
How many times does x go into 2x^2. Put the answer, 2x above the 2x^2. Next mulitply (x-2) by 2x and put the answer under 2x^2. Now subtract that answer from 2x^2 - 10x and we get -6x (-10x - (-4x)).
How many time does x go into -6x. -6 time. Write this above the line and put the answer above the -10x. Next multiply (x-2) by -6 and put the answer under the -6x. Subtract and we get 0 and we are done. If we want to check our answer we can multiply (x-2) and (2x - 6) and we should get 2x^2 - 10 x + 12.
Good luck.
Paul
Oct 03, 2014 | Office Equipment & Supplies
Variable calculator
x=-2
If you're asking how to do this on a particular calculator, please specify the make and mode. If this is homework, be sure to show your work.
Feb 08, 2014 | Office Equipment & Supplies
Finding x and y intercepts
I will not try to make sense of the context (there is no a). You have a linear relation between two variables x and s (y). Here is how you find the x- and y-intercepts.
x-intercepts (or zeros, roots).
The x-intercepts are the values of x when y=0. There could be several x-intercepts.
Set y=0 in the relation 90=6x+3(0) or x=90/6=15. Note: for a linear function y=ax+b there is only one x-intercept.x=-b/a
y-intercept. For a function there can only be one y-intercept.
It is the value of y when x=0
Set x=0 in 90=6(0)+3y, This gives y=90/3=30
The coordinates of the points of intersection of the line with the axes are (15, 0) and (0,30).
Nov 11, 2013 | Computers & Internet
What ia the sulution of 3y-6x=-3
To find the solution, first find the value of y for each equation.
Then substitue one equation into the other so that you only the x variable left.
Then just solve for x.
Once you have a value for x, then you can easily solve for y.
So for the first equation:
3y - 6x = -3
3y = 6x - 3
y = 2x - 1
Now for the second equation:
2y + 8x = 10
2y = -8x + 10
y = -4x + 5
Since both equations equal y, they also equal each other, therefore:
2x - 1 = -4x + 5
Now just solve for x:
2x + 4x = 5 + 1
6x = 6
x=1
Now substitute x=1 into either original equation:
y = 2x - 1
y = 2 (1) - 1
y = 2 - 1
y = 1
Therefore the solution is x=1 and y=1
Good luck, I hope that helps.
Joe.
Nov 09, 2011 | Texas Instruments TI-84 Plus Silver...
Im trying to use Algebra on the new calculator I bought, as its important for my school use. As an example, I write: 3x+3x and that result is 0? How come? Shouldn't it be 6x?
This calculator cannot do algebra ( manipulating expressions with letter symbols) . It does not have a CAS (computer Algebra System). All it can do is evaluate (find the numerical value of) expressions typed in. If it has the appropriate keys to enter variables such as A,B,C, or X and Y., and you entered an expression with variables it will use the numerical values stored in the variables. If you have not stored anything in a variable, it is given the value 0 by default.
Aug 25, 2011 | Texas Instruments TI-30 XIIS Calculator
Hi there. I'm using Casio FX-570ES scientific calculator. I would be glad if you could guide me as to how to obtain derivative of a polynomial expression e.g. y=12(x^2+6)^5
Here is an example. Instead of SIN(X) insert your polynomials.
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
May 28, 2011 | Casio FX-115ES Scientific Calculator
Alok and Bhanu play the following min-max game. Given the expression N = 12 + X*(Y - Z) where X, Y and Z are variables representing single digits (0 to 9), Alok would like to maximize N while Bhanu...
48
the first number will be five and will be subbed for Z
Why? Anything lower could end up X, the multiplier.
Anything higher it could be Y, you could create a negative. Too low
The next two will be nines, because there is no down side
So N=12 + 9(9 - 5)
9*4=36
N = 12 + 36 = 48
Dec 16, 2010 | Puzzle Massey Ferguson Tractor
Graph
What is n?
Press [Y=]. In the Y1= line, type [cos] [6] [ALPHA] [X] [)]
Press [WINDOW]. Enter 0 for Xmin. If n is a variable stored in memory, enter 2N for Xmax. Otherwise enter an appropriate value for Xmax. You might also want to put in better values for Ymin and Ymax, such as -2 and 2, respectively. (For a negative number, be sure to use the [(-)] key next to the decimal point and not the [-] key on the rightmost column.)
Press [GRAPH] to see the graph.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
So im asked to get the derivative of an equation, for example 2x^4+3x^2. I press home, f3, and input my equation, ,x and then press enter. instead of the solution coming out to be 8x^3+6x, the solution...
You have some numerical value stored in the variable x, which the calculator is plugging into the resultant equation.
You can clear individual variables with 2ND [VAR-LINK]. You can clear all one-character variables a-z with 2ND [F6] 1. You can initialize the machine for a new problem with 2ND [F6] 2.
Feb 10, 2010 | Texas Instruments TI-89 Calculator
Memory and memory recal
The STO> button just above the on/off button is your memory store initializer.
example: 2x + 53 STO> y
stores "2x + 53" in a variable named "y".
To recall, just hit y and enter. In fact, if you type an equation like 3y^2 - 4y it will insert the data in for every "y" and give you:
(2x + 53)(6x + 155) as an answer.
To clear the memory:
DelVar y or F6 (2nd+F1) and clear all w/ single character names.
To recall a prevous answer, 2nd+(-) or type ans(1) for the last answer. You can also type ans(2) for the 2nd to last answer & so on.
Jan 30, 2008 | Texas Instruments TI-30 XIIS Calculator
128 people viewed this question
 Grubhead
Grubhead
