Question about Teac PD-D2610 5-Disc CD Changer / Player
Cd disk player won't spin cd - Teac PD-D2610 5-Disc CD Changer / Player
  • 6,784 Answers
HI, this is a basic spin motor fault. This unit will require service at this point. The actual affected motor is buried within the optical assembly, and will require a set of precision tools to disassemble correctly and safely.
Replacing this damaged spin motor will correct this issue.
Posted on Sep 11, 2009
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
Cds won't play
OK, your discription of your problem is rather vague.
Do they try to play but skip or make god awful noises? Or do you have no audio at all?
If they are skipping check to make sure there are no smudges on the underside of the CD. If so clean them with a soft cloth,
Sometimes severe scratches can cas the same problem. You can buff out some scratched using tooth paste or you can by a scratch remover that they sell in stores (it is a gadget that will clean and buff out some scratches available in many stores).
If you have any of the label missing then this is a worse issue. It is actually the top of a CD that you need to be most careful about scratching because if you remove the laquer that protects the silver layer of the CD it will remove part of the silver with it along with any audio or data that is on it. There is no repair for this.
If you have ruled out a damaged or dirty CD then be sure you are not trying to play a CD that has data files intended for computers on a player that cannot open them. The best way to do this is to check the CD on a computer and open the drive folder and view the contents of the disk. Files such as MP3, WAV, WMA and others will not play on a standard CD player. If the files are CDA that is a standard audio CD formatting. So next see if the disk plays on the computer.
If the CD plays on a computer then return to the CD player and attemp playing again. Make sure that the player recognizes the CD being in the tray. Also, verify, if you can that the CD is spinning within the player when you play. If the CD is not spinning or the player does not recognize rge disk try a disk you know to be undamaged.
If you still have problems then you will have to have your player repaired or replace it.
Sep 12, 2012 | Audio Players & Recorders
Won't read the dc
First, Try another DVD to be sure its not just a scratched disk. Make sure the disk is spinning (you will hear and feel it spin up). If its spinning but still wont read you can clean the lens inside the DVD player with a air compressor or can of compressed air. The better solution would be to use a CD designed for cleaning the lens that read the DVD. They are quite cheap and are very nice to have around. If it still will not read then you are much much better off just junking that DVD player and buying another. They do not make replacement parts for DVD players and they are getting very cheap to replace. Good Luck. Thank You
~Kyle~
Aug 16, 2012 | Coby Televison & Video
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Gateway m-1625 CD/DVD-rom won't read any disc. Its spinning but no read. any thoughts?
you might try taking a q tip and some alcohol and clean the eye ( a little glass looking circle ) that reads the disk. Do not touch it with your fingers. Sometimes dust or dirt can get on it and it will not read the disk. This also works on cd players as well as dvd players.
Aug 30, 2011 | Gateway T-1625 Notebook
My pioneer car stereo DEH-P77MP won't play cd's anymore. the radio still works, but on the screen it says cd error AO or A0. i was wondering what problem this code relates to? hope you can help,...
This is a common error with these units when they get dusty from putting dirty disks inside the drive. Just go to your local staples and or walmart and get a 5 dollar disk player cleaning kit. It looks like a plain cd but has small fibers that come out of the bottom of the disc that clean the laser as it spins and tries to read it.
May 09, 2011 | Pioneer DEH-P77MP CD Player
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Teac PD-D2610 5-Disc CD Changer / Player Logo
773 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
