Question about HP OfficeJet 6110 All-In-One InkJet Printer
All the lights on my printer are flashing on my hp 6110 and the cartridge wont move from the right side
    President:
  • HP Master
  • 566 Answers
Check these FAQs:
Also follow the links at the end of the FAQs for morre troubleshooting ideas.
Posted on Sep 11, 2009
Why wont my all in one device copy
for hp office jet 6110 if you have a flashing orange light you will never be able to copy or scan- in addition both print cartridges must have ink,installed & functioning also do you have the user manual?
Aug 19, 2014 | HP Officejet 4500 All-in-One Printer G510G
My hp officejet 6110 all-in-one carriase are stuck completely and cannot remove cartridges either my hp officejet 6110 all-in-one carriase is stuck as for left and want move at all
Try to power off and unplug the printer, then force the carriage to move with your hand
When the carriage moves, place it in the extreme right position, then plug in and power on :D
Aug 17, 2014 | HP OfficeJet 6110 All-In-One InkJet...
Printer cartridge carrier wont move
Have you tried ensuring that he cartridge is correctly inserted in the carrier and hasnot become missaligned for some reason. It can happen! Could it also be a cover not sitting correctly and therefore a microswitch is giving a false reading.
Jun 13, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
All lights rapidly flashing--ink cartridges wont
i had this problem and found that holding down the power button for 5 seconds and then letting it power oww, solved the problem for me. if that fails, unplug the power cord and allow printer to sit for a few minutes. My 6940 gives me a bit too much trouble at times!!!
Dec 26, 2009 | HP Deskjet 6940 InkJet Printer
Hp 6110 remove and check cartridge
this kind of hp printer, have often a specific problem with a cartridge carriage. If you can observe (with a flashlight) inside of cartridge carriage, on the right side of carriage, you can see a small piece of spring made from steel, which is moved from his place, because an broken little piece of plastic.
if you see the spring which is moved, you also may see the hole created by the spring on the electrical contacts of the cartridge carriage.
if you can see the hole... you have a very bad news.
i dont know how much cost the repair of printer, but I tell you, this printer is discontinued.
Sep 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align cartriges message continuously displayed
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
May 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
169 people viewed this question
Seeker5211
Seeker5211
