Question about Kirby Ultimate G Bagged Upright Vacuum
How do I hook up my Kirby Ultimate G for upholstery shampooing?
  • Kirby Expert
  • 324 Answers
Instructions are HERE.
However - be very careful. I'd try somewhere in inconspicuous area first. I personally like spray cans from automotive stores (ones that spray foam). Less mess...
Good Luck,
Rocky
Posted on Sep 19, 2009
  • 430 Answers
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Posted on Sep 11, 2009
2 Suggested Answers
  • 112 Answers
SOURCE: I have a Kirby Ultimate
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used.
Hope this helps!!!
Posted on Feb 24, 2008
Need help to hook up the kirby gun to shampoo
The instruction is HERE. Click on "Spray Gun UPHOLSTERY SHAMPOO)
Good Luck
Rocky
Dec 09, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I use the Upholstery attachment?
Using canister attachments HERE.
If you have in mind "How to SHAMPOO upholstery" then go HERE.
Good Luck,
Rocky
Apr 20, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Mar 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Up and down the stair to shampo it , which methol is best and what attachments to use?
HERE is the instruction on using Kirby to shampoo upholstery and stairs.
But I'd say go to automotive store, buy a spray can for car upholstery for $3-$6 and way less hassle and confusion...
Good Luck
Mar 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Want to shampoo upholostery have a Diamond series can't figure out how to to it
Instructions of upholstery shampoo HERE. Try if it will work well for you on an inconspicuous area before you do entire piece.
Good Luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I shampoo my upholstery
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G rug shampoo attachment
If you still have not shampooed your rugs - here is the Kirby Shampoo Manual ONLINE
Sep 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
I have a Kirby Ultimate G Series. I have misplaced (no, it's not lost...I have it somewhere) the manual. How do I use the upholstery attachment? Does it hook to the outlet on the shampoo tank?
Hope this helps!!!
Feb 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
331 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
