Coleman Mach 15 Air Conditioner
Problem for Coleman Mach 15 Air Conditioner
Will not turn on. Worked fine three months ago...
By kwrichards on Sep 10, 2009
will not turn on. Worked fine three months ago... Checked fuse-ok.
Best Solution
posted on Sep 15, 2009
Very Helpful)
crazyjs69
Rank: Master
Rating: 96%, 7 votes
sounds like you have a bad transformer , if this unit is ran by a t-stat then take the wires of the stat and twist red,yell.,green together if unit comes on your t-stat is bad if not your transformer is bad cost to fix apprx. 60.00 to 100.00 depending on where you take it if you fix your self transformer probly 30.00 tstat about same,hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Coleman Mach 15 Air
Questions and Unsolved Problems for Coleman Mach 15 Air
Do you recommend Coleman Mach 15 Air Conditioner?
Answer
Answer
heater doesnt work..... only get cold air.........
Answer
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down... (More)
Answer
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back... (More)
Answer
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
