Question about Dell (0j539) Modem
Modem is removed
It is saying that the modem is removed
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
Start your system and bring up your device manager. double check your drivers. it sounds like your driver has been corrupted. see if anything in the driver list has and asterisk or a ?. if so try updating your driver. this will reinitialize your modem
Posted on Sep 12, 2009
Trying to sign online and internet says something like error 797 the modem could not connect. We went on Control panel and modem and it says not present. The computer is an E Machine and we have Windows...
The following information comes directly from the Microsoft Website.
So it should solve your problem.
To resolve this issue, remove the modem, and then restart the computer. When the computer restarts, Windows detects the modem and attempts to install the correct driver for it. To do this, follow these steps:
  1. Log on to the computer as administrator or as a member of the Administrators group.
  2. Click Start and then click Control Panel.
  3. Double-click Phone and Modem Options.
  4. Click the Modems tab.
  5. In the The following modems are installed list, click the modem that you want to remove, and then click Remove.
  6. Click Yes in response to the "Are you sure you want to remove the selected modem(s) from your system?" message.
  7. Restart the computer.
  8. The Found New Hardware Wizard starts. Follow the instructions in the wizard to reinstall the modem.
Mar 30, 2011 | E-Machines T1090 PC Desktop
Hallo! I have a problem with my 3G modem (Huawei E1550) When I try too connect It says: error 797! Computer: Netbook MSI wind, OC is windows 7. This modem works perfectly on another computers!
Try the following steps bellow -
  1. Click Start and then click Control Panel.
  2. Double-click Phone and Modem Options.
  3. Click the Modems tab.
  4. In the The following modems are installed list, click the modem that you want to remove, and then click Remove.
  5. Click Yes in response to the "Are you sure you want to remove the selected modem(s) from your system?" message.
  6. Restart the computer. Found New Hardware Wizard will starts. Follow the instructions in the wizard to reinstall the modem.
Nov 03, 2010 | Computers & Internet
I reset my modem and now i can't connect to the internet it says "local only"
You probably removed the keycode in there that told the modem which ISP you were connecting to...not to mention your username/password. Unless a technician TELLS you to reset the modem you NEVER should since it restores the modem to FACTORY DEFAULT SETTINGS. Simply unplugging it for 20 seconds or so should suffice in regards to "resetting it".
You may need to contact your ISP for further assistance with restocking the info in the modem.
Jan 20, 2010 | 2wire (1000-000057-000) Modem
I have only power and ethernet lights on my 4100 B modem. Also, the ethernet light stays lit even when yellow cable is removed! Tech at ISP (AT&T) says the modem is defective. Shouldn't they replace it...
I had a similar problem with my speed stream wireless modem, Etisalat technician attended & replaced with a new modem. It looks to me the problem with Power supply as one of my friend replaced power supply for the modem and the problem resolved but my case, I had to change the modem itself.
Sajid-Abu Dhabi,U.A.E
Jun 03, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Wrong installation of the modem using win xp sp3
Remove the device from your installed devices, then restart the computer and get it to detect the device from scratch.
Are you sure you have the right device drivers for it?
Apr 26, 2009 | U.S. Robotics (USR5633A) Modem
Last light on modem not working
reset the modem by removing power for a coulpe of minutes and then power it up wait a minute for the modem to reset and then try to connect to the internet
kind regards and please don't forget to rate us
Dec 11, 2008 | NetGear DM602 ADSL-Modem
Compaq Microcom 420 PCMCIA Modem not working
Windows has installed the wrong device driver.
Go to device manager and remove the drivers then install the driver from the manufacturer.
Apr 02, 2017 | Compaq Microcom Computers & Internet
Hi I have a Toshiba A10 notepad and it's suffering a few problems. First of all, it says a error message 797 when trying to connect to the Internet. I've checked Modem Properties and also Modem in use,...
hi,
goto device manager, right ckick the modem and uninstall it. then press F5 or press scan for hardware changes tool button. then go for the new device install with the driver of the modem available with you. if this doesnt work, let me know
thank you
Jul 29, 2008 | Computers & Internet
Every time we try to use the internet it says unable to find server, if we unplug the ntl modem and plug it straight back in the internet connects how do we solve this
sounds like the internet connection is not setup to Ur modem. When u unplug it redetects the modem and connects. try uninstalling the modem from the control panel - system - device manager. keep the modem connected and reboot. U may have to use control panel - add/remove programs any programs the modem cd installed. on reboot use the modem cd only to get the driver and let windows control the modem.
May 26, 2008 | Computers & Internet
Help please intructons are not helping
The fixed cable from the modem should be plugged into the computer, remove the modem cable from the computer and plug it into the 'internet/wan port" on the back of the wireless router. start the router and connect to it wirelessly. BPCS
Dec 27, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
See all Dell (0j539) Modem Questions
Dell (0j539) Modem Logo
62 people viewed this question
Alun Cox
