Question about Kenmore 63942 Dryer
Dryer will not start
My dryer will not start, when I turn the time setting switch and press the start buttom it does not start. I can here a humming noise when I turn the time switch. But nothing happens. I hope that you can tell me what is wrong with it.
James
  • 2 more comments
  • jdcanfixit Dec 10, 2007
    none
  • Anonymous Feb 13, 2008
    kenmore dryer does not start model #1106221210 i have replaced the timer and it did not fix the problem.I checked the 220 thats fine, i have also checked the power cord that is fine ..... I am stumped....help please....
  • Douglas Peterson Mar 05, 2008
    kenmore dryer, it doesn't always turn on when the start button is pressed it goes click, click sometimes I can get it to turn on but it doesn't always finish the cycle. Does anyone have a similar problem?
  • Anonymous Jun 25, 2008
    the dryer will not turn yet the heatis still coming out
It is probably the thermal fuse that is bad. This has detected a hot condition in the exhaust vent of the dryer and blown. It is an easy and cheap fix to replace it.
Posted on Dec 17, 2007
  • 625 Answers
When you turn the select knob, you set up the internal cams of the timer. when you press to start or pull to start, you energize the timer motor (buzz) the timer opens the water solenoids. the diaphragm switch senses the water level and moves the timer to the next step. agitate starts for the timed cycle. when its finished the motor kicks in in opposite direction to drain and pump water out.
Posted on Dec 11, 2007
Cabrio Dryer not turning on when hit start button
If it makes a humming noise, as if it's trying to start, you most likely have a defective motor.
Feb 26, 2014 | Dryers
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 06, 2012 | Kenmore Dryers
My dryer will only run if i hold in the door switch button and turn the drum while i hit the start button.
Jun 04, 2012 | Maytag Dryers
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
Feb 27, 2012 | KitchenAid Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
When selecting a dryer time, then pressing start,
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 26, 2010 | Frigidaire FER311FS Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Dryer won't run
Its time to call the repairman. If its the motor humming its either bad or the dryer is froze up and unable to turn causing the motor to hum. Eventually it will trip the breaker.
Nov 06, 2007 | Amana ALG331RAW Gas Dryer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Kenmore 63942 Dryer Logo
171 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
