Question about Lincoln Welding Tools
The wire come out red hot but won't welded.
The wire come out hot but won't welded
  • 92 Answers
Check and make sure you have a good ground connection.Also make sure the speed of the wire is turned up hi enough.
Posted on Sep 12, 2009
2 Suggested Answers
  • 81 Answers
SOURCE: when trying to weld,the feed wire gets red hot
There are loose connections and / or a short in the gun.
sounds like the gun is grounded, and the gun is welding the wire to itself.
Posted on Apr 21, 2010
Have a solar 2160 wire feed welder but do not seem to have any heat control.can't weld sheet metal,just way to hot.
The capacitor(s) may be open. or resistor has failed. It is also possible heat selector is fused to the one setting.
Nov 20, 2012 | Welding Tools
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
I HAVE A LINCOLN 175 MIG WELDER THAT WHEN I GROUND IT AND PULL THE TRIGGER THE WIRE GETS RED HOT AND BREAKS AT THE FEEDER. I DON'T KNOW WHAT THE PROBLEM IS.
Hello, do you have the welding tip in the nozzle? This tip provides the proper grounding of the electrode wire.
Feb 21, 2011 | Lincoln Welding Tools
Sir, we are using machine mounted MIG welding torches.Before these torches are working properly, now we got problem i.e, nozzle became red hot, cos of this we had stopped our production. pls suggest me.The...
Ensure that you are using the correct contact tip in the welding gun, if the tip is too short; the cup will fill with splatter and submit excess heat to the cup.
Also, make sure if you are using a name brand gun 'miller, lincoln etc' to use THEIR contact tips, the miller guns use a special tip 'the threads on the tip are mashed into the gun ensuring maximum contact for high amperage welding' if the wrong tip is used, it will overheat and jam the wire.
Another thing to remember is to check the amperage rating on the actual gun itself; you may have a 150 amp maximum gun on a 300 amp welding unit.
Good luck
Feb 09, 2011 | Lenox 21172 Welding Torch
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
When trying to weld,the feed wire gets red hot
Feb 16, 2010 | Welding Tools
Having problem with heat range.
Try keeping your heat setting hot, but increase your wire speed and regulate your welding speed accordingly. How does the weld look with your settings where you started?
Aug 07, 2009 | Welding Tools
Plug wiring
When wiring a new plug for which voltage input?
The cutter has a white wire, a black wire, and a green one - white is the neutral line, black is the hot line, green is ground.
You can see this in section 4-9 of the owners manual, if you don't have a manual you can go to www.millerwelds.com and get a PDF file of the manual.
Rank this answer please,
Carl
Nov 26, 2008 | Miller Welding Tools
Welding Tools Logo
56 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
