Question about Western Digital imicro IM35ST320SI 3.5 IDE HDD External Enclosure and WD250G SATA Hard Drive
Drive will not copy files to it
I am attempting to connect my external hard drive of the specified type to a macintosh laptop. It will read the external hard drive but it acts as if the files and read only and will not let me copy or modify any file on the drive. This is frustrating since the function of an external hard drive is to copy files to it. I tried using it on a dell latitude D830 and it worked fine. It copied files onto it without a problem.
  • Anonymous Mar 20, 2014
    sony vaio vgn fw11m
    President:
  • 1,015 Answers
The Macintosh OS may not work with the drive due to the file system on the drive was created with windows. The drive may have to be re-formatted with the Mac to work on it. Now I don't use a Mac so I assuming the OS will have a problem with FAT32 or NTFS format that windows uses....I could be wrong.
Posted on Sep 10, 2009
When I turn on the computer it boots to "boot to restore disk"
There are several potentials for this problem. The umbrella concern is that the operating system does not appear to be recognized from the hard drive. The problem could be a faulty hard drive (unlikely if you have not heard noise from the drive or you have not had earlier symptoms of read/write problems). The hard drive might be corrupted because of a malware/virus problem. The operating system might be contaminated (no specific reason other than the operating system is not being read and loaded into RAM). If you have critical data on the drive and you have not backed up the hard drive, I would suggest getting an external drive kit from an IT site (Office Depot, CDW, etc) that will handle the drive type and pin configuration for your hard drive. Some laptop hard drives use a 42 pin configuration, others a 44-pin configuration. The more diverse the pin option the better your chances of getting a connection to the drive. The external drive kit will generally allow you to transfer your data files to a second source (another computer or external media storage) via a USB cable and then you can attempt a system rebuild with an operating system disk. If you are not comfortable doing the rebuild or pulling the hard drive from your laptop, make sure your techie saves your data files before rebuilding. Too often the rebuild is accomplished with no attempt to save the data files.
Dec 26, 2013 | Computers & Internet
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
I have simply forgotten how to put stuff from my computer on to my external hard drive. I know it was pretty easy, but nothing cpomes up on my screen to go by. Thanks, Rochelle
The process is dependent upon whether you have an Apple Macintosh or Windows PC-branded computer. I will provide instructions for both.
Windows
Plug the hard drive into your computer. Then follow these steps.
1. Click the Windows logo button in the lower left corner of your screen to open the start menu. 2. If using Windows XP, click 'My Computer' on the right side of the menu that pops up. If using Windows Vista or Windows 7, click 'Computer'. 3. The window that opens will display all of the hard drives and other similar devices connected to your computer. Look for your external hard drive. Typically, the letter of the alphabet assigned to the drive will not be 'C:/' or 'D:/', but some other letter further down the line. 4. Double-click your external hard drive's name or icon. Another window will open. This is the contents of your external drive. 5. To copy files to the external hard drive, first locate the file you wish to copy wherever it might be on your computer. Then, click on the file you want to copy and while holding down the left mouse button, drag it into the window for your external hard drive. 6. The file is now copied. The same action can be taken if you also wish to copy whole folders.
Macintosh
Connect the hard drive to your computer, typically via a USB port.
1. The hard drive should show up as an orange icon on your desktop. Double-click this icon to access the contents of your hard drive. 2. To locate files, click on the smiling, rectangular face-shaped icon in the lower left corner. This is the Finder, and it allows you to find your files. 3. Once you've navigated to the file(s) you desire, (these are generally located in the folder along the left side of the window labeled with your name) click on the file names and drag them to the external hard drive icon, which is also located in the left sidebar of the finder window.
This will copy the files to the hard drive.
Hope this helps. If you would like more assistance, feel free to reply to this solution.
Thank you for using FixYa!
Mar 18, 2011 | Computers & Internet
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
How do you download files from external drive to a hard drive?
Select the file you want to download to the computer hard disk, right click your selection and click on copy. Open the folder you want to download the file to and right click a space in the folder and select pest. The file will be downloaded to the specified folder.
Aug 08, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
HOW TO FORMAT A ZIP DRIVE FOR MACINTOSH SYSTEM 7.6.1. I need to copy data from my old mac's hard drive in order to copy it to a new machine.
Format on your old Macintosh using standard Mac HFS, then your new Mac will read the files without problems. Reformat the discs if they came pre-formatted for DOS as the filenames won't copy properly and will be very slow to read/write If your new Mac is FireWire/USB only, then you'll need to track down a USB Zip drive (the 100Mg or 250meg versions will read your discs ok.)
Dec 23, 2009 | Iomega ZIP 100 MB SCSI (10011) External...
WD passport 250GB harddrive
Is your laptop a Macintosh and your desktop a PC (running Windows)?
If so, your drive is likely formatted in Macintosh file system and your PC can't read it. Your iPod is formattted in a PC file system and thus both your Mac and your PC can read it.
Dec 17, 2007 | Computers & Internet
Open Questions:
Western Digital imicro IM35ST320SI 3.5 IDE HDD External Enclosure and WD250G SATA Hard Drive Logo
161 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
