Ge washer we talked about sat the 5th bought the motor inverter 160.00 put it on wed the 9th washed 2 loads did fine, 3rd load same problem wont agitate or spin please help model number wjsr4160g1vww
  • 2 more comments
  • karen_lilly7 Sep 10, 2009
    motor is not coming on to turn drive wheel on bottom of drum
    want to know if you recieved the last comment
  • karen_lilly7 Sep 11, 2009
    we talked with someone on the 5th and was told the motor invert was bad because the green light was flashing, we replaced the invert and it worked fine spinning and agitating through 2 loads, then same problem on the 3rd load not agitating or spinning model wjsr4160g1vww , the motor is not coming on to turndrive wheel on the bottom of drum on new motor we have 7 green light flashing please respond thanks
    yes we will try it if not workin will check back thanks
  • 15,935 Answers
If the motor is NOT running - it is likely a simple lid switch problem.
FIND IT HERE
You can test the switch as being defective by simply jumpering the 2 wires together.
This is a safety device - so should be replaced asap.
Thanks for using FixYa.
Posted on Sep 11, 2009
  • 854 Answers
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin fr
Posted on Sep 10, 2009
Front load electrolux washer wont spin showed e58 now after attempting system clean e 57
According to the alarm code E58 is usually a washing machine with inverter and means problem with inverter board or motor or wiring between inverter-motor.
Could be:
E58 - Inverter is drawing too much current (> 4.5A).
Abnormal motor operation (overload).
Motor-inverter wiring faulty.
Motor faulty.
Inverter board faulty.
E57 - Inverter is drawing too much current (>15A)
Motor faulty.
Dado
Feb 10, 2013 | Electrolux Washing Machines
Front Load wcvh6260 GE front load washer.
I dont think this is a problem with the motor or inverter board.
Check if there is a control device in the machine that is stopping the motor half way through the wash cycle
Apr 27, 2012 | Exercise & Fitness
My ge wjre5550h1ww wont spin. everything else work up to that point
Might need to be reset. To Reset the Inverter board on the motor push the timer knob in so the washer is idle or if digital have the machine in the off position. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. This might take more than one time. Service Manual and MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2011 | GE WBSR3140DW Top Load Washer
Why won't my washer spin? It is balanced & the load is small and balanced also.
Their is a strong possibility a momentary power glitch has tripped the motor inverter. You can reset the inverter. To Reset the Inverter board on the motor push the timer knob in so the washer is idle or if digital have the machine in the off position. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. This might take more than one time.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. I took the time to write a note about it for Fixya: How it works GE Hydrowave washer
I included a service manual there also. Hopefully you will be able to reset it. If you can't a fuse may need to be replaced. I included details there also. Thanks for using Fixya.e4e3910.gif
Aug 31, 2010 | GE Profile WPRE6100G Top Load Washer
My ge washer wont spin by itself. i have to take
it sounds to me like your motor is defective, maybe, just the start switch, but best to replace motor...Bruce
Oct 10, 2009 | GE WDSR2080D Top Load Washer
Wont spin
1.The timer control may not be advancing to the spin cycle
2. The most likely problem is a damaged coupling between the motor and the tub. If this is the problem, your clothes are not being washed either. Check to see that the agitator is working when the wash cycle starts.
May 16, 2009 | GE WBSR3140DW Top Load Washer
My font load washer wont spin or drain
You will need to to replace the inverter
Jan 07, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
