Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer keeps powering up and turning off.
Occasionally, when it does stay on it tells me to properly shut it down.
    President:
  • HP Master
  • 566 Answers
Check these HP FAQS for your printer:
Posted on Sep 11, 2009
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
Mitsubishi TV, WD 60735; TV shuts off shortly after powering up.
It could be but a couple of other possible reasons---they had problems with this set and its brothers with caps in the main power supply puffing up and causing this "hard to turn on" issue.
A second reason is dust/dirt inside the unit.
All air is coming in via the front of the set and exits the rear--enough dust gets inside and the fans slow down or the lamp gets too hot and set shuts down---don't try this in the house: we take them with back cover off outside the building (on a ramp) and with air clean them out completely--try not to blow it inside the screen. It looks like a dust storm in most cases but can cause exactly the problem you have.
Apr 23, 2012 | Mitsubishi WD-60735 Projection Television
When fisrt turning computer on monitor shuts down ,have to keep turning it off and on until it finally stays on
Check the cable connections [VGA & power] and ensure they are properly connected.
Try switching the power cables with the PC and see how the monitor fairs.If it properly operates with the PC cable,then replace its cable.If there's no change, take the monitor to a repair shop and have it fixed.
Hope this helps.Thanks!
Please rate this answer.
Oct 27, 2011 | Computers & Internet
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
Cartridges do not Move & the Printer Shut Downs Automatically
tell if the cartridge iss moving a litle or is totaly bloched
Sep 06, 2009 | Canon Pixma iP6210D InkJet Photo Printer
I have a HP C6180 All-In-One, I am trying to set up the wireless printing. I had this enabled at my old house, I recently moved and now it will not work. When I turn on the wireless radio and try to print,...
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer..its a known issue with the HP printers.
you can also follow the follow the link..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01507846&cc=us&lc=en&dlc=en
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
