I have a akai tv problem. it shows a black screen and a red lock key sign how do i fixit?
  • 2 more comments
  • tha_player_1 Sep 10, 2009
    it still doesn't work i have a akai CT2009 tv that's the model of the tv
    hi i'm trying to fix my tv problem here.. i have an akai CT2009 Tv that shows a black screen and a red key sign how can i fix it???
  • tha_player_1 Sep 11, 2009
    what does p/p mean and where can i find it on my remote??
    i have a problem with my akai Ct2009 tv. it shows a black screen and a red key sign. i'd asked for help allready but none of them did not help me get the tv fixed.. hellpppp meee pleaseeeeee
  • 164 Answers
Option 1:
Simultaneous press + & - on local panel and
then power on with main switch.
Exit:
POWER.
option 2:
PRESS MUTE,OK,TV IN SEQUENCE
option 3:
1) Turn on your TV. If the TV requests your secret code, press the "QV"
button and the "9" button on the remote control at the same time.
2)Press the MENU button to view the main menu. Use the ADJUST button to
select "Advanced" Features". Press ENTER/EXCH.
3) Use the ADJUST button to select "Use Parental Lock". Press
ENTER/EXCH.
4) Press press the "QV" button and the "9" button on the remote control
at the same time, instead of entering the code.
5) If you were using "Lock the TV", the lock must be turned off. Using
the ADJUST up/down buttons, select the "Off" setting.
6) If you were using the "Lock the Channel", use the ADJUST up/down
buttons to place the cursor next to the channel whose lock you want to
turn off. Press ENTER/EXCH.
7) Press the CANCEL button to unlock that channel or use the ADJUST
up/down buttons to change the channel to a new one.
8) Press the MENU button to return to the "Advanced Features".
IMPORTANT
YOU MUST USE THE REMOTE CONTROL INCLUDED WITH THIS TV. YOU CANNOT US A
REMOTE CONTROL FROM ANOTHER MITSUBISHI COMPONENT AND YOU CANNOT USE
"UNIVERSAL" REMOTES FROM OTHER MANUFACTURERS
I hope one of the options work for you...Good Luck.
Posted on Sep 11, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow this procedure to unlock your tv--
Switch off your TV for 15-20 minutes, now switch it ON. PRESS P/P twice in quick succession, bypasses and allows access to Menu to reset it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 10, 2009
  • Rylee Smith
    Rylee Smith Sep 11, 2009
    P.mode/P size. It will be on the bottom left hand corner of your akai remote.
    Thanks
    Rylee
  • 4,806 Answers
Hold the display button on the remote control for 10-15 seconds.
Or you can enter the default password when you see the lock appear, the default password is 0000 (four zero's).
If this does not work please post me the model number of the TV.
Good luck.
  • Lee Hodgson
    Lee Hodgson Sep 11, 2009
    PRESS P/P twice on the remote in quick succession, that should allow you into the menu to reset it.
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
Unlock Tv
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Feb 21, 2009 | Apex Digital GT3215 32" TV
Unlock tv akai ct2009
press F+Mute same time
Nov 02, 2008 | Televison & Video
Akai ct2009 tv
i cant find out how to hook any of my dvd players to my akai ct2009.
Aug 10, 2008 | Akai CFT2490 24" TV
AKAI TV UNLOCK
i have nec 42" lcd tv have lost remote and cant do anything as child lock is on can only turn of at mains can anyone please help to unlock?
Jul 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
TV Locked
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Dec 24, 2007 | Mitsubishi VS-45609 TV
Authorized Repair Centers for Akai Flat Panel TV
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
Key on tv can't view anything only sound
Someone has locked out access to functions. Possible "parental key". Check menu settings for this. If user used a password, you will need it
Oct 29, 2007 | Akai PT4298HD Rear Projection Television
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
