Sometime get me error 101, when I try to open only Gmail site in IE, Google crome & when I try to after 15 mints its opening.
Give me below error:
Error 101 (net::ERR_CONNECTION_RESET): Unknown error
plz help me
Yes - this seems to be an access/permissions issue, and various Windows updates seem to trigger different defaults, even if you've changed this before.
Open Explore (right click on Start)
Go to C:/Windows/Temp folder
Right click on the Temp Folder.
Choose PROPERTIES.
Choose the SECURITY tab.
Choose the EDIT button.
Make sure you have full permission (allow) for your user name.
If you are the only one using your computer, you can give full allow access for each profile listed.
Click on the APPLY button, SAVE it.
Restart your browser.
It should fix the problem.
Usually this happens when the installer
fails to create a temporary directory to extract installer contents.
Can you check your read/write permissions on your %TEMP% directory to
allow this? To do so, follow these steps:
1. Go to Start > Run
2. Type %USERPROFILE%\Local Settings and click OK.
3. Right-click the Temp folder.
4. Locate the Security tab and ensure that Read and Write permissions are not denied. Adjust settings as necessary.
5. Click Apply and then OK.
Http://www.getnetgoing.com/Internet-Explorer-cannot-display-the-webpage.html
This will definetely help
It worked for me (:
Rest dns settings...u can use command port to reset dns setting "netsh int ip reset reset.log" hit enter and type this command "netsh winsock reset catalog" now restart your comuter and log into facebook...:)
Got THIS:
LOCATION IS NOT AVAILABLE
c:\Users\Dell\Local Settings
ACCESS IS DENIED
***NOW*** what do I do? How can I be denied access to my OWN local settings on my own private computer that is not networked?***HOW*** do I access my local settings????
I also got this problem after I installed download accelerator om my laptop...after unstalling it it vanished !!
I downloaded and bought the regcure and it worked for a few times an now the 101 error is back , does anyone else have this problem it is pissing me right off
Am also the same problem as you Tina, did you find the solution for this
SOURCE: Error 101 (net::ERR_CONNECTION_RESET): Unknown error. I
Facebook has a internal problem and I am also not able to log into my account but this is a temporary problem, it will solve after some time.
