Question about Bagatrix Pre-Algebra Solved! 2005 (205101) for PC
4 and a little 3 half way up the 4 it is a verbel expression and i need to know what it means?
  • 66 Answers
Possibly "four to the power of 3"? as in
"4 x 4 x 4"
Posted on Sep 11, 2009
Can you help me on this question?
This answer is correct. 4/12 divided by 2/2= 1/3
The reciprocal of 2/2 is 2/2
Then you multiply straight across and reduce to get 1/3
Mar 01, 2015 | Miscellaneous
Mitsubishi express
temp sensor, clogged coolent system, or air trapped in the cooling system. Thermostat in backwards, or faulty gauge.
Dec 17, 2013 | Cars & Trucks
I need to know what are all the multiplication symbols and what they are called.
The ways to express multiplication
X: Cross aXb means a times b
. dot 3.a means three times a or 3 a
No sign : implied multiplication (3a+5)(2b-7)=(3a+5)X(2b-7)
Repeated multiplication aXaXaXa= a^4. This is read a to the 4th power, or a exponent 4.
More Multiplications
With vectors you have two other types of multiplication.
Scalar product (also called dot product) vect(a).vect(b)
Vector product; vec(a)Xvec(b)
You have multiplication of complex numbers, and multiplications of matrices, multiplication of tensors.
Oct 21, 2013 | Cell Phones
Looking for advice on a video card. Would a radeon hd 5750 run on c51gm motherboard
1) You have a PCI Express x16 expansion slot, for a graphics card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135010
(Orange)
A) 1GigaByte of graphics memory which is GDDR3. (It is GDDR3, not DDR3; trust me)
B) 800MegaHertz Core Clock
C) 1600MHz Memory Clock
D) API's - DirectX 11
Open GL 4.1
Shader Model 5.0
2) The motherboard chipset is an Nvidia GeForce 6100 - Northbridge, and an Nvidia nForce 410 - Southbridge.
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series_chip_specifications
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Nvidia GeForce 6100/nForce 410, came out 2005.
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip of the motherboard chipset, handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
AGP technology, and PCI Express technology, ARE HIGH-speed graphics.
Using a PCI slot for a graphics card, or using Integrated Graphics; is NOT high speed graphics.
(As you can see in the Motherboard Diagram, the PCI bus is controlled by the Southbridge chip. The Southbridge chip handles the Slower capabilities of a computer.
Means anything connected to the PCI bus, such as a graphics card in a PCI expansion slot; is handled by the Southbridge chip.
Integrated graphics also )
4) PCI Express came out 2004.
Went from PCI Express 1.0 version to PCI Express 1.1 version.
In 2007 PCI Express went to the 2.0 version. PCI Express 2.0.
Your motherboard, IMHO, uses the PCI Express 1.1 technology.
This is why I recommend a graphics card based on the PCI Express 2.0 technology. (For one)
PCI Express 2.0 is Backward Compatible, with PCI Express 1.1
A little iffy if it's PCI Express 1.0
I have seen a lot of problems crop up with users trying to use a graphics card, based on the PCI Express 2.1 technology; on a motherboard based on the PCI Express 2.1 technology.
That's why I recommended PCI Express 2.0
PCI Express 3.0 is supposed to overcome that, (Use on a mobo with PCI-E 1.1), but I have no real world knowledge, (Hands on), and no input from the 'outside'. (Internet/world)
5) You need at least a 400 Watt power supply. Don't have at least a 400 Watt? Time to move up.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147669&Sku=U12-41529
Regards,
joecoolvette
Nov 20, 2012 | ECS C51GM-M Motherboard
Give some example of math equation?
The following are examples of expressions:
x
3 + 7
2 × y + 5
2 + 6 × (4 - 2)
z + 3 × (8 - z)
Example:
Roland weighs 70 kilograms, and Mark weighs k kilograms. Write an expression for their combined weight. The combined weight in kilograms of these two people is the sum of their weights, which is 70 + k.
Example:
A car travels down the freeway at 55 kilometers per hour. Write an expression for the distance the car will have traveled after h hours. Distance equals rate times time, so the distance traveled is equal to 55 × h..
Example:
There are 2000 liters of water in a swimming pool. Water is filling the pool at the rate of 100 liters per minute. Write an expression for the amount of water, in liters, in the swimming pool after m minutes. The amount of water added to the pool after m minutes will be 100 liters per minute times m, or 100 × m. Since we started with 2000 liters of water in the pool, we add this to the amount of water added to the pool to get the expression 100 × m + 2000.
To evaluate an expression at some number means we replace a variable in an expression with the number, and simplify the expression.
Example:
Evaluate the expression 4 × z + 12 when z = 15.
We replace each occurrence of z with the number 15, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
4 × z + 12 becomes
4 × 15 + 12 =
60 + 12 =
72
Example:
Evaluate the expression (1 + z) × 2 + 12 ÷ 3 - z when z = 4.
We replace each occurrence of z with the number 4, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
(1 + z) × 2 + 12 ÷ 3 - z becomes
(1 + 4) × 2 + 12 ÷ 3 - 4 =
5 × 2 + 12 ÷ 3 - 4 =
10 + 4 - 4 =
10.
hope that help you
Jun 22, 2011 | LeapFrog Turbo Twist Math Cartridge 5th...
What is 8m3n4+4m2n4???
Let us rewrite it trying to respect math usage. (I have to make sense of what you wrote). m^3 means the cube of m, n^4 means n to the 4th power.
8*(m^3)*(n^4) + 4*(m^2)*(n^4)
If this is what you meant, read on. If not, well ignore what follows, and don't blame me for not being a mind-reader.
The terms are not similar (m^3) and (m^2), so you cannot reduce the whole expression to a single term. You can extract the common factor 4*(m^2)*(n^4).
This will give 4*(m^2)*(n^4)* (2*m +1)
That is all you can do with it.
Jan 16, 2010 | Casio Office Equipment & Supplies
LOW BRAKE PEDAL ON 4 WHEEL DISK BRAKES
Check the pads/rotors to see if they need to be replaced.
Check the brake fluid level. If low it could mean the pads/rotors need to be replaced. If replacing also replace the brake fluid.
Two years probably means you need a brake job.
Otherwise you may have air in the brake lines which you can bleed off.
May 07, 2009 | 1999 Chrysler 300M
I would like to know where the aircon filters sit in the renault modus 1.4 expression. I would also lokie to know if anyone can help with a workshop manual for the renault mondus 1.4 expression.
Under the black plastic cover that hides half the engine department.
You need to remove some torx screws in order to get access underneath to the cabine or aircon filter.
Apr 10, 2009 | 2006 Renault Le Car
Lost rice cooking instructions
From the users guide for the 550 FOR BROWN RICE RICE: 2 half cups WATER: To 2 mark, plus 3/4 cup TIME: 32 minutes MAKES: 2 cups RICE:4 cups WATER: To 4 mark, plus 3/4 cup TIME: 39 minutes MAKES: 8 cups Here are the rest: 6 cups To 6 mark, plus 3/4 cup 44 minutes 13-1/2 cups 8 cups To 8 mark, plus 3/4 cup 48 - 49 minutes 15 cups 10 cups To 10 mark, plus 3/4 cup 51 - 52 minutes 21 cups Here is a link to the user guide for all the instructions. http://www.blackanddeckerappliances.com/dyn/prod/user-guide/139/RC410%20RC550.pdf
Jun 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Bagatrix Pre-Algebra Solved! 2005 (205101) for PC Logo
74 people viewed this question
Top Bagatrix Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Are you a Bagatrix Computer and Internet Expert? Answer questions, earn points and help others
