Question about HP OfficeJet 6110 All-In-One InkJet Printer
I have the same priblem
Grinding noise and I cannot turn my machine on anymore...
    President:
  • HP Master
  • 566 Answers
Check these FAQs for your printer:
Also check the links at the bottom of the FAQs for more troubleshooting advice.
Posted on Sep 11, 2009
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
Grinding washing machine agitator
more than likely the pump is the part that is making the noise. You can verify this by leaning the machine back where you can see the pulleys, your pump will be the one in the back. Remove the belt and each pulley should turn smoothly. The part number for the pump is 35-6780
May 28, 2012 | Maytag Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
I have Kenmore washer,model #110.28882790. grinding noise when in spin cycle. not spinning! What is possible defects?
Sounds like the washers drive coupling is broken. Part number 285753A. The coupling connects the motor to the transmission and when it breaks it can make a grinding noise. Since it is not turning the transmission anymore it cannot spin. Hope this helps
Aug 30, 2011 | Kenmore Washing Machines
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Washer won't pump out water makes a grinding noise when turned on
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Washing Machines
Big heavy load ,will not spin anymore. Makes grinding noise when trying to spin.
Your motor has a clutch on it, it is your clutch. It is not a cheap fix sorry.
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
, battery loses its charge, grinding noise
it sound like your alternater has gone bad. and your trany is bad you will have to replace it
Jun 11, 2009 | 2000 Hyundai Elantra
HP OfficeJet 6110 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
