MT645 has setup cleared. Need to know how to
MT645 has setup cleared. Need to know how to setup again.
I need to change the password on my verizon router I do not have verizon internet can you please help me ?
It is clear you have not setup encryption within the router. You need to access your router, go into the router setup and setup security normal wpa2 or wep pending your computers and operating system in use. It will ask you for a secret passkey to enter. Without having this setup any one can cannot to your wireless router. But once the passkey has been setup only you will be able to access it. Very easy fix. if your do not know how to access your router control follow the instruction manual that cam with it, it is normally well explained or just contact me again. regards Hands of Time.
Jul 16, 2014 | Westell Wirespeed Computers & Internet
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Were is the web page for bt.com/signupmybt
where do I sign up to stop paper billing?
Apr 15, 2013 | Tally MT645 Printer
Hi How do I clear BIOS password set by misstake on Acer Travelmate 2413 LCI? I can not get in to BIOS setup
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Feb 01, 2011 | Acer TravelMate 2413LCi Notebook
Does anyone have serial pinout for mannesman tally mt645 printer.
Pin Signal
1 Chassis Ground
2 (TxD) Transmit Data
3 (RxD) Receive Data
11 & 19 (RTS) Request to Send
5 (CTS) Clear to Send
6 (DSR) Data Set Ready
7 Signal Ground
20 (DTR) (Busy) Data Terminal Ready
Feb 19, 2010 | Tally MT645 Printer
Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
May 22, 2009 | Tally MT645 Printer
My laptop compaq armada1700 ask me power-on password what can i do?
Follow the instructions of the service manual for the Armada 1700 (you need to have some skills):
2.2 Clearing Passwords
The power-on password prevents use of the computer until the password is entered. The setup password prevents unauthorized changes to Computer Setup. To clear the passwords, you must remove all power from the system board. If you do not know the passwords, use the following procedure to clear the password:
1. Remove all battery packs from the battery bay and MultiBay, if applicable.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait five minutes.
5. Reconnect the AC power.
6. Restart the computer. During Power-On Self Test (POST, a "162 System Options not set" message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10.Proceed with the troubleshooting procedures.
Point 10 means you need to do the setup via disquette to set the date and time again, to avoid the "162 system option not set" message of the POST.
Lucas from Argentina
Mar 22, 2009 | Compaq Armada 1700 Notebook
I hooked my Belkin-G-Plus-Mimo-39000 to my laptop. Got it working, now I wanted to get it on my Desktop. its installed, but its asking for a NETWORK KEY. What to do from here.
The Network Key is the method for encrypting a transmission on a wireless network. If you originally setup your wireless router you should know this key. Otherwise, contact whomever setup your wireless router and ask what the key may be. You will want to ask whether it is WEP or WPA as well.
To reset, you can clear the key if you can login to the router, otherwise holding the reset button while the router is unplugged will clear the key (and all the other settings so this might be dangerous). To clear it, hold the button for at least ten seconds.
After a clear, you will need to setup the router again. Consult your documentation if you have it. If it is a netgear or linksys, use IP 192.168.1.1 User=Admin password=Administrator, if you have a D-Link, try IP 192.168.0.1 and User=Admin password=Admin. If it is something else, try either of the previous combos. (unless it is a Cisco, then it is 10.0.0.2 User=Administrator password=Cisco).
Hope this helps, even a little.
Jul 18, 2008 | Belkin Computers & Internet
22 people viewed this question
k24674
jasbo
jasbo
