Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Replaced a water inlet valve but the wiring connections fit either way. How do I tell which side is up?
  • 22 Answers
Most of the time the connector matches the coil color or the terminals are different sizes. If you bought an aftermarket valve just hook up and try the water dispenser. No water? Swap the terminals and try again. No Water? The valve is either defective (unlikely) or you have defective switch in the dispenser.
Posted on Sep 12, 2009
KSSC48QMS01 water drips from the feed tube for the ice maker in the freezer compartment how do you access the water valve under the fridge?
Hi carey_ritche,
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Before testing the water inlet valve, unplug the refrigerator to avoid an electrical shock hazard.
-->The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
-->Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
-->Test the water inlet valve for continuity using a multitester. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | KitchenAid KSSC42FMS Side by Side...
Water is not coming out of the dispenser and ice maker is not working.I just replaced the water filter with a new one, and nothing seems to be working?
HI. This will be a water inlet valve issue. The procedure below will guide you through the necessary inspection needed to confirm the damage.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Dec 13, 2009 | Kenmore 57029 Side by Side Refrigerator
The water dispenser will not shut off right away when the glass is removed.
HI. this will occur when the water inlet valve is clogged with debris. this will cause the valve to stick, or not close properly. follow the procedure below to inspect the valve for mechanical damage. replace if needed.
Nov 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator water dispenser won't stop after being pressed and constantly drips after water source is turned off. Whirlpool Model #ED22PQXFW01 SN #SJ4236632
Hi. This will usually be the fault of the water inlet valve. The solenoid based valve may have debris building up, thus, causing the valve not to close properly, after usage. Kindly, follow the procedure below to confirm the damage, replace the valve, if needed.
Nov 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have an Amana side by side model SRD20S4E. The ice maker has stopped working. It appears the water is not coming into the ice maker. Would it be the valve? Not sure how to test to see if the water is...
Hi. The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink, but normally behind the unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Nov 21, 2009 | Amana SXD524VW Side by Side Refrigerator
My whirlpool refrigerator ice maker does not make ice and the in door water dispenser does not dispense water
HI, i would check the temperature in the unit to make sure it is not to low. this will cause the lines to freeze over. If the lines are not frozen, i would advise to move on to the water inlet valve.
Sep 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Amana icemaker & water dispenser has stopped working. Water is no longer flowing into the system. What would be the most likely cause? Note: the actual product # is SXD27NL, which is not listed, but...
HI. This is an inlet issue.
Sep 14, 2009 | Amana SXD524VW Side by Side Refrigerator
Water dispenser don't work.
HI. this is an inlet issue.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not dispensing in side by side Whirlpool refrigerator
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Jul 22, 2009 | Whirlpool GS6NBEXR Side by Side...
Water dispenser not working
HI, first you will need to check the water line. make sure it isn't frozen. if the lines are ok, you will need to inspect the water inlet valve assembly. this is a dual assembly and, one side may be able to operate while the other may be faulty.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors.
Also, you can Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
NOTE( Make sure to test only the affected side of the valve terminals(dispenser side). If the dispenser side is faulty, replace the entire valve.
Jul 21, 2009 | GE GSH25JFR Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
