Question about JBL 6-1/2\ Round Coaxial Speaker By Prospec Electronics" Speaker
I HAVE 2 CABINETS THAT IM PUTTING 3- 15" JBL SPEAKERSPER CABINET THEY ARE FOR OUR BAND. HOW WOULD I WIRE SPEAKERS TOGETHER. IM AM USING BEHRINGER 2400 AMPS
    President:
  • 1,851 Answers
In order to give you details for connecting the speakers I need to know:
Each speaker details (nominal impedance and handling power).
Since the Behringer 2400 is a discounted model (or misspelled model), the lowest output impedance that this amplifier can handle.
Is there any possibility to plug both the cabinets at the same amplifier?
Reply at this post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 27, 2010
Can I add a 4ohm 4x10 speaker cabinet to the lineout port in back of the Behringer 3000A
No. The line out is at line level, not amplified to speaker level. Yu can run a powered cabinet, but not a passive one.
Jun 04, 2016 | Fender Music
How can I service Behringer epa900 speaker
Can't say for sure....there should be a bunch of screws in the back so you can gain access....is this a powered cabinet??...can you dis-connect the present speaker and horn and hook up another just to make a test?? Is the cabinet plastic?? There could be loose screws....Does the cabinet have a recess for a stand??If so, check the retaining screws in that as well....and don't forget to check the grill....
Oct 13, 2014 | Behringer Europort EPA900 Ultra compact...
How to open the behringer b215xl cabinet and replace the horn?
These days, most speaker cabinets are sealed with access gained only through the front. With the front grille removed, check the horn to find out whether it is attached to the cabinet with screws.
Sep 05, 2012 | Behringer B215xl 15 Inch 2 Way Speaker...
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
I have a set of teac speakers that are about 40 years old and I need to replace a woofer. I just do not know which one to buy. The speakers were bought in Germany, the model number is LS-80 and they have...
These sound like they a JBL speaker.
1. You will need the impedence and diameter spec and the Hz (hertz) specifications to get a replacement set.
you can call JBL Altec-Lansing is the company that manufacturer this series of speaker.\ On the back of you speaker cabinet should be a phone number to the company or check the user manual that you received with the speaker system and they should be able to give full information on how to replace the speaker in question or where to have it repaired.
The cabinet is glued together and will need a cabinet expert to disassemble.
Contact JBL for more information.
Mar 10, 2010 | Electronics - Others
Hi have a pmp3000 what are the most suitable bass bins and tops (speakers) to use for a two piece 60s band with semi acoustic guitar and a bass, irun the bass through a 15'' h and k bass amp and i bring a...
Have you considered any of the Behringer cabinets that are recommended companion pieces for this mixer. For more expensive gear have a look at JBL cabinets. The EON series is good. Have a look at what other bands you know are using and listen to their sound to see if its what you like.
Oct 27, 2009 | Music
Broke one end of the cable that connects my 2 behringer ms20 speakers.Which replacement part do i need?
What input were you plugged into? If you are talking about the cable that connects the two cabinets from right speaker to left speaker, it looks like a standard RCA cable to me. It basically connects the signal content from the right cabinet to the left cabinet. It should be a shielded unbalanced RCA to RCA cable.
May 13, 2009 | Behringer MS20 Digital Monitor Stereo...
Even Distribution
i have same speakers try these setting and tell me what you think put phase at 180 and put switch on lfe mode not normal for some reason my sub plays louder on these setting verse phase on 0 and lfe switch on normal i have power on subwoofer a little more than half also set croosover to 80hz you will never touch it again
Dec 05, 2008 | JBL Northridge E 250P Subwoofer
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
JBL 6-1/2\ Round Coaxial Speaker  By Prospec Electronics" Speaker Logo
80 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
