Question about Zippy EL-610 Electron Luminescent Keyboard
Number pad how do i switch off the numbers around the letters m,j,k,l,u,i,o,p,; etc
  • 56 Answers
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Posted on Dec 10, 2007
    Problem Solver:
  • 16 Answers
If you turn off numlock then your numpad will not work. That is what the numlock option is for.
With numlock off you have to use the number keys at top of keyboard above the qwerty letters.
Posted on Apr 22, 2010
My numpad doas not work if i turn off num lock the keys /*-+ work but no the numbers please help
Posted on Jul 12, 2008
Chromo tablet
You can't put letters on the number pad but you can change your password to be made up of letters. You do this by going to settings, security, then at the top of the page it will say number pad or something, you click on that, then follow the instructions.
Jul 20, 2014 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
How do I use the letters on the number pad?
you must read your owner manual, for indication. download from www.retrevo.com or www.manualslib.com
However if the problem is when you hit, NOT key is activaded you must open the keypads, for clean it, from oxide, corrosion, dirty, with contacts cleaner.
God bless you
Nov 25, 2013 | Logitech Harmony 650 Remote Control
I press certain letter keys and numbers appear, the number keys are fine just the letters, what is the fix for this error?
You have your numbers lock on, press the NumLk key and that should correct it. You will notice on you keyboard that there are small numbers on it below some of the letters, this is so you can use the keyboard has a 10 key number pad/ calculator etc. If pressing the NumLk key does not work, the key may be stuck or you have a bad keyboard
Oct 12, 2010 | Panasonic Toughbook CF-51 Notebook
Keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
Apr 13, 2010 | Lenovo IdeaPad S10-1208U Netbook
My numbers 1234789 in letter pad don`t work.But if i pres 3,4,5 at one time will open Help in Google Chrome
The numbers five and six don't seem to work on my letter pad. All other number keys work fine. I have a Dell Inspiron notebook. Does anyone know how I can fix this? HELP!!!!
Dec 04, 2009 | Computers & Internet
Activation of the number pad so instead of letters, numbers are appearing. still need to press the Fn key to get the desired letter.
Hi, try pressing the numlock key - this should put the number pad as standatd until it is pressed again, when it will revert to letters.
May 15, 2009 | Computers & Internet
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
May 22, 2008 | Sentry Fireproof Safe
Zippy EL-610 Electron Luminescent Keyboard Logo
428 people viewed this question
Top Zippy Computers & Internet Experts
gbob59
 Mikey
Mikey
Ed Watson
Level 1 Expert
Are you a Zippy Computer and Internet Expert? Answer questions, earn points and help others
