Question about Acer Aspire 5920-6727 Notebook
My aspire 5920 dvd/cd tray doesn't eject or recognize cd's or dvd's,?r.s.v.p
    Novelist:
  • 142 Answers
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK.
  4. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  5. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  6. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  10. On the Edit menu, click Delete.
  11. When you are prompted to confirm the deletion, click Yes.
  12. Exit Registry Editor.
  13. Restart the computer.
Posted on Sep 10, 2009
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
Acer laptop computer. I can't eject the CD.
Click on the middle button of the CD Tray to eject it or Go to My Computer, right click on the CD/DVD ROM icon & click Eject. If still it is not ejecting, then perform the below steps:
Start>Control Panel> Hardware and Sound> Device Manager> Click the (+) sign, in front of DVD/CD ROM> right on the driver listed & click UNINSTALL. Restart the computer
Mar 18, 2010 | Acer Aspire 3000 Notebook
How to open dvd or cd drive acer computer
1. There should be a button in the middle of the CDROM tray, click on it and it will eject the CDROM Tray.
2. Open My Computer> Right click on CD/DVDROM icon & click eject.
Mar 12, 2010 | Acer Aspire 5610-4648 Notebook
Well we have a acer computer and the cd drive is stuck
If pressing the eject button does not eject the tray, look for the small pin hole on the cd drive and insert a paper clip to press that hole. It would manually eject your CD tray. Hope this helps.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
/cd/DVD eject hole
Most CD/DVD drives have a tiny hole just below the tray. Straighten a paper clip in gently insert it into this hole and push it in. The tray will slide out slightly, just grab the tray and pull it out to the open position.
Oct 30, 2009 | Acer Aspire L100 PC Desktop
I have an Acer Aspire laptop 5335 series that has a DVD stuck. Is there a way to manually eject it?
Under the eject button in the CD tray, there is a little hole, insert a clip carefully to force release of the tray. The computer can be on or off.
Aug 25, 2009 | Acer Aspire 5335-2257 Notebook
How do i replace the dvd/cd drive? acer aspire 9410Z
Hi there.
Eject the CD tray and turn off the laptop, underneath the laptop you will find a screw that holds the CD/DVD in place, once you have removed the screw pull gently on the tray and it will slide out and you can install the new drive.
Good luck and thanks for using FixYa!!
May 11, 2009 | Acer Aspire 9410 Notebook
My CD drive won't Eject
Hi there.
There are 2 ways you can eject the DVD tray,
1st, double click on computer, right click on the DVD icon and select "eject" from the sub menu.
2nd, find a paperclip and straighten it, have a close look at the DVD near the eject button, you will find a small hole, poke the paperclip in and manually eject the tray.
Good luck and thanks for using Fixya!!
Mar 04, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5920-6727 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
