Question about Bose Lifestyle 48 System
Connect lifestyle 48 to plasma and dvr
How do I connect my Bose Lifestyle 48 to my Samsung plasma and my Comcast Motorola HD DVR box? I use the HDMI cable to connect the DVR to the tv, and the audio jacks for the Bose. I have to use my tv's speakers for the cable, and only get Bose surround when I play a DVD.
Any suggestions? I'd like to keep using the HDMI cable for my connection from the cable to the tv so I can get the highest signal there. I don't have a way to connect an HDMI cable to my Lifestyle box. If I'm out of luck, that answer would be helpful, too!
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Posted on Sep 29, 2009
    Scholar:
  • 76 Answers
Unfortunately, BOSE does not do HD yet so the only way to get around it, is to run all of your inputs (DVR etc) throught the TV and use an audio out from the TV to the BOSE in order to get your surround sound. If you still wish to use the BOSE to play DVD's, you will have to settle for either composite output (yellow/white/red) or component output (green,blue,red + white red).
Posted on Sep 13, 2009
Testimonial: "Thank you for the straight information! Very easy to understand and (soon) to implement. I appreciate it!"
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Home Theater install
yes sounds about right what you are doing as long as you have 2 digital audio 'inputs' on your Bose to get the audio from the dvd player and cable box. Apart from your last part "I will then use Digital Audio from the Bose to the TV." The tv will only downrate the audio to two channel stereo, so its not worth puting audio through the tv as you only get stereo anyway, so might as well let the tvs speakers power it out themselves.
Aug 17, 2007 | Bose Lifestyle 28 System
Bose Lifestyle 48 System Logo
1,083 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
