Whirlpool washer trying to replace lid switch
Help needed! cant see the switch on the lid is it inside somewhere and how do you do it?? says on the new packet that it is an easy task to change it??? help please
  • 53 Answers
There are 2 screws on the back of the console. one on each side facing downward. Remove them and pull the console forward and lift. Under the console you will see 2 brass looking clips on both sides going into the cabinet. Take a screwdriver and pop these out of the cabinet. Unplug the lid switch from the cabinet. Pulling the cabinet forward from thr top, the whole cabinet will come off exposing your lid switch. Reverse steps to assemble
Posted on Sep 11, 2009
Testimonial: "sounds easy! thank you, my son will give it a go he fixes black hawk helicopters so I'm hoping!!"
Whirlpool cabrio washer, I try to start a load by pushing the start button, the lid lock clicks shut like normal but then the light starts blinking and the washer wont run.
If it's the lid locking light that's flashing, then the Lid Latch assembly needs to be replaced. It's latching, but the switch inside it isn't working and doesn't recognize that it's latched.
They have the part and a video on how to fix it at this parts company.
http://www.appliancepartspros.com/whirlpool-latch-w10404050-ap5263307.html
Oct 03, 2016 | Whirlpool Washing Machines
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Ultimate Care II - Top loading washer The water will not drain prior to the spin cylce - Please help
The lid switch is the most probablle cause for this problem.Check the lid switch lift the lid and close it if you cant hear a click replace the lid switch.
Dec 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer LA8580XWWI
you have a bad lid switch. you will need to replace the switch.
Oct 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to install the switch lid
The following link explains how to install a lid switch on a Whirlpool model top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have any questions about this repair, or if your lid switch is located somewhere other than what I have described, please let me know. I hope this helps you.
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont start
No power
Lid switch
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY WASHER IS FULL OF WATER BUT WILL NOT START CYCLE. POWER IS ON TO THE WASHER
Need to replace your lid switch.
Dec 18, 2008 | Whirlpool GSW9800PW Washer
DOES NOT TURN ON
need to replace lid switch.
Washer will not run pump
Check your lid switch. This is a tell tale symptom of a lid switch gone bad. The washer fills, agitates, but will not spin or drain. The lid switch is located along the right hand side of the lid opening on most models, but some newer models have a switch in the left rear of the lid. Simply open and shut the lid several times and listen for a distinctive "click" of the lid switch as you open and close the lid. A lid switch usually runs about $35 to replace. If you provide me with your washer model number (usually located under the lid somewhere) I can give you the part number you need. That is...if the lid switch is the problem. The only other problem that I have encountered that caused the same symptoms, was a bad timer. Timer vs Lid Switch: Lid switch is a cheaper fix. I would try this option first. Let me know if this helps and/or if you need more guidance.
Sep 21, 2007 | Whirlpool LSR6232J Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
