Question about HP VP6310 Multimedia Projector
VP6310 Colour problem
When I switch on the projector, the colours look great, but just after 3 to 5 minutes, it seems as if I lost one colour. The picture will turn green / brown. It seems as if the Blue is missing. The Lamp is only 66 hrs old. When I switch off and switch on after an Hour, the same thing happens. All cooling fans are working. It seems that this problem occurs when the projector gets warm. What can the problem be please? Thanks, Jesmond
    Problem Solver:
  • 18 Answers
You need to replace the color wheel sensor. I can fix it.
Posted on Jun 06, 2009
Colour balance
does it look like that when you view the menu? Across all sources?
Apr 23, 2013 | Mitsubishi XD510U DLP Projector
New Colour Wheel Mixing up Colors on Dell Projector
Could be just 180degrees out of phase on the motor spindle and sensor or damage caused by broken material from the old wheel.
Apr 21, 2017 | Dell M209X Ultra Mobile Projector ...
The picture suffers from colour fringing
either the color wheel has lost a segment or the colorwheel index needs to be adjusted in the hidden menu using the color ramps test screen.
Jul 20, 2010 | InFocus ScreenPlay 4805 Multimedia...
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Optoma DV10 color wheel
Okay, I recently had a loud noise coming from my projector and found online meterial stating that the colour wheel had been damaged. So with a bit of guts I managed to open the projector and found the colour wheel missing a segment.
I removed the colour wheel and the broken piece of the segement and tried to contact Optoma. Optoma turned round and said they cannot sell me the the colour wheel, which got me very upset. Some people claim online that Optoma will sell you the part on a back order at £50. (if you can be a little specific on how you managed to convince them to sell you the part, would be great).
The only option I had available was to send my project to them and they would repair for an estimated cost of £125+VAT. Guess what, you can buy the entire projector off ebay for 150quid!!!
Anyways after fiddling around quite a big online I got fedup and decided to glue the broken segment together and it SOLVED the loud vibration problem. I have colour and picture.
Becareful not to tighten the colour wheel screw too tight orelse it will break another piece of segement (Like I did).
Here are instructions on how to open up the projector.
http://www.geekfest.info/DV10/dv10.html
I cannot guarantee this will work for you as it depends on how badly you have shattered the colour wheel segment, so do at your own risk. I had two piece of the segment broken and a third by tightening the colour wheel screw too tight.
This will work for awhile but the colour wheel does need replaceing one day. If anyone can tell me how you can get Optoma to sell you the colour wheel would be great.
Best of Luck
Aug 08, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
HP VP6310 Multimedia Projector Logo
221 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
