Question about HP LaserJet 3055 All-In-One Printer
Just installed new print cartridge 12A Q2612A. Am getting message that says "no print cartridge". Also the yellow exclamation symbol under ready is blinking. I have removed the cartridge several times and re-started the printer several times but continue to get the above
  • 2 more comments
  • marguerite littlefield Sep 10, 2009
    it is an official hp cartridge
    i removed the tab
    i wiped the area where the cartridge sits with warm water
    did not work
    when i turn on the printer - Hewllett Packard is in the small window
    double arrows start from left to right - get into the 8th position then i get
    "no print cartridge" and the yellow exclamation symbol is flashing
    are you sending me another solution - i'm confused, should i continue to go to my email or will you write on this screen
    have installed New HP print cartridge
    have removed tab
    have wiped area where cartridge sits with warm water per earlier suggestion
    after turning on printer - Hewlett Packard is seen in small window - double arrows start from left to right to the 8th position then i get the message "no print cartridge"
    you're a genius.............this worked - the printer is now printing. am going to try printing from my computer later but for now, removing the paper did reset the message and was able to print from the machine
    thank you very much
  • 854 Answers
"No Print Cartridge " message is displayed on the HP LaserJet product's control panel, even though a cartridge is present. The same message can be triggered on the HP LaserJet 101x series products. Resolution Follow these steps:
  1. Remove all paper from the input tray.
  2. Open and close the door.
  3. Reinsert the paper into the input tray.
  4. Powercycle (turn off and back on) the printer.
The error will then go away. FW Datecode 20040330 update: Since the message on the control panel is confusing, the message has been updated from "No Print Cartridge " to now display "Check Cartridge/Check Paper Tray " message. NOTE: It is important to remember that regardless of which printer is being used, or which revision of device firmware is being used, the resolution is the same; removed all of the paper from the paper tray, restack the paper and reinsert it into the paper tray. This will position the input paper so that the engine sensor will not be tripped. Description The printer uses a physical sensor to detect whether or not a cartridge is present in the device. This sensor is mechanically linked to a second sensor that detects whether or not there is a jam in the pick-up area of the paper path. Since these two sensors are linked, when a jam occurs in the pick-up area, the engine does not know if there is an actual jam or if the cartridge is missing. The printer uses an algorithm to choose between a jam message and a missing cartridge message based on whether or not the cartridge door has been opened. If the door has not been opened recently, it is determined to be a jam. If the door has been opened recently, then the cartridge is missing. Therefore, if there is a jam in this area and the door is opened and closed without the jam being cleared, the printer believes the cartridge is missing. The error is generally seen when a jam occurs that involves multiple pages that are staggered throughout the paper path. Most of the jammed pages are cleared by opening the door, removing the paper in the path, and then closing the door. Occasionally, some pieces of paper are picked and only advanced into the paper path by approximately 1 or 1.5 inches. These mis-picked pages might not be obvious because it is hard to see that these pages are actually in the paper path since the pages have moved such a small distance. This is when the "No Print Cartridge " message is incorrectly displayed. The "No Print Cartridge " message is confusing if the pages have only advanced an inch out of the paper tray - removing the cartridge will not show the problem as the paper has not advanced far enough to be seen from the inside of the printer.
Posted on Sep 10, 2009
    Top Expert:
  • HP Master
  • 75,066 Answers
Is this a new cartridge or a refilled one? if it is refilled the machine will not recognize it and will not work, the new cart has a chip in it to id that it is a genuine HP, they did this to stop us from saving money by using so called re-manufactured cartridges.If this is a new HP then clean the socket where the cartridge goes with warm water, also make sure u removed the protective plastic film off the print head of the cartridge
My 12A cartridge after refilling,giving wet type print
If you are getting smearing then likely the drum is dragging. If you simply added more toner without emptying the waste bin that would be the reason.
Aug 17, 2015 | HP 12A Toner (Q2612A) Printer
After refilling and fitted to printer. The Printer shows complaint "No Printer Cartridge"
due to dust or carbon sometime printer show warning message after refilling. you must clean it carefully or attach it again. if still problem will not resolve, clean your area of cartridge with some cleaning liquid that connects with printer (silver or golden area which have pins) and connect. if your printer is working but jst showing message about cartridge is not original or printer have no cartridge then plz ignore that message.
Sep 26, 2014 | HP 12A Toner (Q2612A) Printer
Why does my new HP Laserjet 1020 12A cartridge print too light?
It's rare that an original HP would do that? It's more likely that it's a compatible / remanufactured cartridge. is it? Compatibles can be as good as or better than OEM (mine are for example), but there are a lot of "hacks" out there.
Either way, I would return it for a new one, because that is your problem.
*please rate me :)
Mar 25, 2009 | HP DeskJet F380 All-In-One Printer
Why is it printing only black? I have a 12A Q2612A cartridge installed
Try a "hard restart", which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You also might visit the manufacturer's website, to see what solutions are being offered for printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Jul 03, 2008 | HP LaserJet 2840 Printer
This printer is a MONO laserjet printer meaning it can only print in black colour.
If you want a fax/copy/printer that does colour you would need something like a HP Colour Laserjet 2840.
Feb 19, 2008 | HP LaserJet 3050 All-In-One Printer
How to refill toner in 12a of hp
http://www.q2612x.com/refillinginfo.htm#basic
Dec 20, 2007 | HP 645A Magenta Toner Cartridge (C9733A)...
HP LaserJet 3055 All-In-One Printer Logo
Seeker5211
Seeker5211
