Question about Memory Cards & USB Flash Drives
Help can you tell me how do i work my mp3 player? I was tried to open the chase, and clean it by alcohol, i thought it was just off all the time since i'd connect it with network computers
SOURCE: 2 gb memory card wont format but it reads on my mp3 player as emp
i want password for memorycard hy71uto1gm-mph
Posted on May 13, 2009
0 characters
1 Points
Cd drive won't open and cds are very sticky
Yes without doubt. If alcohol hasnt fixed it try a little liquid detergent. otherwise you may want to copy the CD's onto new disks and keep the problem ones as backups
Aug 01, 2009 | Memory Cards & USB Flash Drives
May 12, 2009 | SanDisk 2GB microSD Memory Card
I cant use my transcend mp3 player in such functions like data transfering or copy when i connect it to my pc
hey it may becoz of not installing ur mp3 players driver cd... so try to install it first and try.. becoz in all the new player there are some problems like this..
Oct 16, 2008 | Transcend (589307) Media
Troubleshooting Sylvania smps1018 mp3 player
I think that your pc needs the driver for your mp3. If you look around on the net, I'm sure you'll be able to download one.
If you've done this, like i usually sugest, do a reset, but only a soft-reset, so it just refreshes your mp3, and doesn't wipe the songs off.
I dont have this particular model, but i thought i'd give some general advice, as i've had similar problems on the past.
Kaz D
Aug 02, 2008 | Memory Cards & USB Flash Drives
Mitone 1gb mp3 player
see connect to internet and from my computer check for device manager there you will see in the list of hardware that your unknown device will be listed right click on it and properties from there you update your driver from internet!!hope this solves your problem
Feb 06, 2008 | Memory Cards & USB Flash Drives
Mp3 mp4 player
hi there
try and download this SIV (System Information Viewer) 3.28
this will identify whats the make of your mp3/mp4 player.
after identifying your make, post it here and we will try and find out the driver.
hope this helps.
Feb 05, 2008 | Memory Cards & USB Flash Drives
My MP3 player was fine for the while that I had it.. All of a sudden, I couldn't turn it on.. When I did it says "Boost Error! Shutting Down!" and I've tried to format the MP3 player, I've tried to delete...
well i think there is some charging discharging problem ,go for repair!!!try and update its software see if it works oderwise repair is the only option!!
Jan 30, 2008 | RCA (DVDCP33) Media
How to delete songs from phillips mp3player
SOUNDS LIKE YOU NEED TO CONNECT YOUR MP3 player to your computer open the music folder from the mp3 delete every song then try and down load the music from your computers music library
Dec 02, 2007 | Philips LM1200 PHILLIPS 12" 2GB OPTICAL...
Pearl mp3 player
i cant load music my computer cant detect it
Nov 08, 2007 | RCA (DVDCP33) Media
Mp3 player
Backup your MP3 player's Files into your computer then Format the Mp3 player using Windows.
Sep 18, 2007 | Memory Cards & USB Flash Drives
Memory Cards & USB Flash Drives Logo
14 people viewed this question
Top Memory Cards & USB Flash Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Memory Card and USB Flash Drive Expert? Answer questions, earn points and help others
