Question about Apple Macintosh Keyboard
How do i fix a key on a keyboard that is not typing the letter all the time
    Scholar:
  • 85 Answers
Things to try:
1. Blow the dust out of it and clean the crud out from under the keys.
2. You can very gently pop out the key and remove the little rubber cap under it and clean the contact. I usually use a pencil eraser very gently. also clean under the little rubber cap a bit. and reassemble.
3. Worse come to worse swap out the offending key assembly with the ~ key. and relabel the new key with either whiteout or a magic marker depending on key color. Also great for laptops that are missing keys.
4. get a new keyboard.
Posted on Sep 10, 2009
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
My keyboard automatically typing letter y and apostrophe's..
Sounds like the keyboard might be bad. Run your fingers thru the keys in a sweepting motion and see if that stops the keyboard from continously typing keys on the screen. If that doesn't do it then its time for a replacement keyboard.
Apr 29, 2010 | ASUS 90-A4C1K1000 Keyboard
When i type on my keyboard i am getting numbers instead of letters on certain keys, how do i change it back?
if you have a compact keyboard or have a laptop look for a fn key on the bottom then look for a numlk button press them both at the same time then try to type that should fix it
Feb 09, 2010 | Computers & Internet
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
Jul 20, 2009 | Logitech 9675020403 Keyboard
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keyboard typing something other than the letters it should
Check to see if you have your num lock on...still does not please restart your PC / laptop.
Jan 13, 2009 | Dell Computers & Internet
Type letter and get number on keyboard
Hold down the Function Key and the F11 key at the same time. That should reset your keyboard to the letter.
Dec 04, 2008 | IBM ThinkPad T23 2647 Notebook
Keyboard & Mouse Problem
Seems like you Ctrl-key is pressed all the time somehow.
Make sure that none of the Ctrl-keys is stuck.
If you try another keyboard, everything should work fine, so just check your keyboard. Maybe you need to replace it.
Apr 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
Apple Macintosh Keyboard Logo
434 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
