Question about Honeywell Programmable Thermostat Heater
I have Honeywell thermostat (RTH230B). The heat set works well, but cool set does not work. My air condition works well with my old thermostat. What's the problem. Thanks
    Guru:
  • Honeywell Master
  • 587 Answers
Do you have an Rh and Rc terminal on t'stat and do you have 4 wires coming into it?
If you do then you need to put a jumper wire from Rh toRc.
Posted on Sep 11, 2009
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
357 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
