Question about HP Office Equipment & Supplies
Hp2420 when i print i get a blank sheet first then the printed one
    President:
  • HP Master
  • 566 Answers
Check the printer settings to see if the printer was set to add a blank page to the beginning of all print jobs.
This procedure changes the printer settings for a print job:
  1. Click the Start button
  2. Point to Settings
  3. Point to Printers (Windows 2000) or Printers and Faxes (Windows XP).
  4. Right-click the HP LaserJet driver you plan to use (2420)
  5. Click Properties .
  6. On the Advanced tab, uncheck Separator Page.
  7. Click OK to return to the Advanced tab.
  8. Click OK to save the settings.
To change the default settings for your printer, use the following steps for Windows 2000 and Windows XP computers.
  1. Click the Start button.
  2. Point to Settings .
  6. On the Advanced tab, click Printing Defaults .
  7. Change any of the settings on the tabs. These settings become the defaults for the printer.
  8. Click OK to return to the Advanced tab.
  9. Click OK to save the settings and to close the printer driver.
Posted on Sep 11, 2009
  • adoch Mar 21, 2011
    I use Windows XP and after clicking on 'Printing Defaults' there was no option available to cancel the separator page so I clicked on 'Print Processor' and changed the Driver from Winprint to MS XPS and that seems to have fixed that problem, however I'm not sure if it will cause other problems! I had this problem when I initially installed my HP Printer and was able to resolve it but could not remember how. It was not a problem for years but I just recently upgraded to the latest version and that problem reoccured so it's something HP needs to fix.
My HP laser 2420d will not print. Meaning, it will not display information in the screen from print preview not will it display any of the information on paper. It prints out a blank sheet of typed...
Clarification please.
"It prints out a blank sheet of typed information"
Is it printing out a blank sheet or is it printing out typed information????? It can't do both.
"it will not display information in the screen" What screen are you talking about?
Nov 09, 2010 | HP LaserJet 2420 Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Prints blank sheets
No, they need to be replaced.
Did you remove the plastic tape from the carts?
Jan 31, 2009 | HP Photosmart C3180 All-In-One InkJet...
Try to print mapquest directions and sends blank sheet out
Internet printing can be tricky because everything is in HTML which is not designed for printing but for clicking. So there are links and features but when you try to print it can be blank or half pages. Is there a button on the site that says printable view or print these directions or something similar? If you click on that it should allow you to print the page as you see it on your screen.
Jan 28, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
293 people viewed this question
Seeker5211
Seeker5211
