Hello hembreegerry,
If you like a lot of bass, you definitely need to consider another amp. The SP2X-300 is only rated at 170 watts RMS into 4 ohms mono. That would barely be enough to power one small sub. You do not specify what brand and model your subs are, their impedance, or their power handling capacity. But for any subs, your best power solution is to add together the individual RMS power handling capacity and select a monoblock amp that provides close to the maximum at the impedance they will be wired to present. For example, if your subs are 4 ohms and have a maximum RMS of 250 watts, you would want an amp that outputs abour 500 watts into 2 ohms (2 4 ohm subs wired in parallel = 2 ohm load). An ideal amp in that example would be the Alpine MRP-M500 which outputs 500 watts RMS into 2 ohms.
Hope this helps.
