Question about Sony Playstation 3 (PS3) Console
The multi Video does not work in my PS3
Only the DHMI side in my PS3 works but it will not work with the regular cables
When you power up the machine, continue to hold down the power button past the initial beeps and wait for a beep after about 3 seconds. This will flip it from HDMI to default video output. It makes no other changes to the PS3 except default video output. You might have to cycle the power on the TV as my Samsung kills the AV input from the PS3 when it is not sending AV.
Posted on Sep 13, 2009
    Problem Solver:
  • 11 Answers
Go to video settings and select the type of cables you are going to use
Posted on Sep 10, 2009
TH-L32C20X does not read hdmi cable
is the driver installed on the computer you are using at the minute?
Feb 12, 2013 | Panasonic TH-L32C20X 32 inch Multi-System...
The new AV cable will not fit into the slot in the ps3. Used a regular composite cable prior to trying the new HD cable.
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks .
click here to download repair guide... u can do this by yourself....
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
Ps3 80 gig pixalated on hd screen beond reading.
That is usually a problem with the motherboard graphics chip. You would need a motherboard gpu reflow. To check this, connect a non dhmi cable to see if the same problem occurs,
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
My ps3 does not work after i used the hdmi cable on my friends new t.v. when i came back to my house i put in back on my older tv to use the regular cable and the screen is just black. what could be wrong...
This is because the PS3 is trying to outpur in Digital... you have to reset the video output to work on your analog tv again... try this.
turn the unit off... if it is on hold the power button on the unit.
while the unit is off hold the power button untill it beeps, then go into the setup and reset the proper settings for your tv.
Jan 28, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not working with the output. doesnt show the ps3 screen
you have to go to the output settings under the settings option on the ps3 home screen and change it to multi and then go to the input on your tv and say yes to the question
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
No connection on ps3 to t.v.
try resetting your video settings.....see if this helps, otherwise you could have a bad video cable or PS3.
Hook up your origional cable that came with Ps3..the red, yellow, white one.
1. Turn off PS3 with switch on back
2. Turn switch back on. Red light should be on.
3. press and hold power button for approx 8 seconds till multi beeps are heard. Turn off and back on. See if you get a pic...If not your ps3 might be broken, or bad video cable.
Jan 05, 2008 | Sony Playstation 3 (PS3) Console
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
144 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
