My Fuji F50 has developed a fault whereby it's stuck with the message 'Focus Error' on the screen. The lens is unable to retract. I get beeps and an unfamiliar electronic buzz when I turn it on or off. I've tried taking the battery out and have been through the controls to no avail.
Works on any camera like this OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online ++++Thanks for using FIXYA
I can't solve this problem, but I can offer this warning about the advice nettiser gave.... do NOT try to use a standard air compressor. Most tend to spit out condensate (water + oil) along with the stream of air. You'd make the problem worse by spraying more water inside your lens!
Canned air can give similar problems if the can is tilted and the liquid propellent flys out... a problem all too familiar to pro photographers and darkrom techs.
I have a Finepix F50 fd. Suddenly some of the picture settings are failing - the screen goes black...
(More)
I have a Finepix F50 fd. Suddenly some of the picture settings are failing - the screen goes black and the small light adjacent to the settings wheel flashes! Any suggestions? Teri
fuji finepixf50fd - grainy pictures even when on auto- I would like to try installing factory...
(More)
fuji finepixf50fd - grainy pictures even when on auto- I would like to try installing factory settings to see if that sorts it but don't know how.
I'm having 2 problems with my camera: 1 sometimes the lens doesnt retract if you switch it off 2 I...
(More)
I'm having 2 problems with my camera: 1 sometimes the lens doesnt retract if you switch it off 2 I get a 'read error' message and am unable to access all the photos from memory. Not sure if this a camera or a memory card problem. Any suggestions? Jan
I have a fujifilm f50se and it is the second time I download the pictures from the camera to PC with...
(More)
I have a fujifilm f50se and it is the second time I download the pictures from the camera to PC with Vista and have a i/o error and process aborted and can't download anymore pictures to PC
my camara(fujifilm f50fd) shows lens error when switched on and it doesn't want to take picture how...
(More)
my camara(fujifilm f50fd) shows lens error when switched on and it doesn't want to take picture how to i fix it pls help
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
