Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-55809 I am having problems with color separation which stated happening recently and seems to be getting worse. Sometimes power off an on helps for a few minutes. The 3 colors seem to seperate around words etc especially on the edges. The screen also seems to have a bend to it. When I went into advanced convergence (conv-audio button) the center seems fine but all the 4 corners have a bend and the white line with the 3 colors all separated by like a quarter inch ! I can't seem to adjust this. Up and down separation is bad but left to right seems pretty good ? ? The TV is about 6 years old- is it worth fixing ? Thanks !
  • Harker Dec 10, 2007
    Thank you- any input on the 2 items below-
    Any idea on approx cost so I know if an estimate sounds reasonable ? Sounds like you are saying it is definitily worth fixing
    Also it does not look there there is an authorized service center to close to us- There is a Sears and the TV shop I bought my TV from. Am I safe using them or do you stongly suggest the auth center ??? THANKS AGAIN !
  • 232 Answers
Harker, the convergence circuit has failed, IC`s and possibly a couple of support resistors, that`s a good set, call around to your local shops and get a few estimates, waay better set than the new dlp and lcd sets in my opinion, any questions? e-mail me back, Happy Holidays, BMW Rider
Posted on Dec 10, 2007
  • Larry Eastman
    Larry Eastman Dec 10, 2007
    Harker, either of those places can fix the set, you don`t need an "authorized dealer" for that repair, be advised that Sears will be a LOT more expensive to do the same job. As to how much it will cost that really depends on where you live, Shop rental rates, and overhead differ dramatically say between a NYC suburb and
    a small town in nearby Connecticut. By calling the shop and saying " I need the convergence IC`s replaced in my tv" they know there dealing with an "informed" consumer and should be able to quote you an estimate, be sure to have your model number ready when you call, good luck, BMW Rider
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi WS-55809. i just came home from vacation and turned on my tv and nothing. the power comes on and nothing comes up on the screen. i tried to scroll through the inputs to make sure it...
Sometimes the convergence IC's failing will cause this. Also, the coolant for the picture tube can leak onto the circuit boards causing damage. Need to have it looked at asap as the coolant problem gets continuously worse.
Jul 29, 2010 | Mitsubishi WS-55809 55" Rear Projection...
WS-55809 cloudy foggy picture
Check the EHT splitter assembly, this feeds the focus grids on the output tubes.
BE CAREFUL as there is more than 25kVolts there!
Apr 23, 2017 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
In your On Screen Display menu (OSD), you should have a place that says "convergence". As a sub heading to this it will say "Auto-Convergence". This is where you want to be! Hit OK under AUTO, and watch the magic happen! If your set happens NOT to have AUTO, you'll have to do it manually. You're going to make the lines all match up doing one color at a time until all three colors are done! It's not hard at all. It may take a little patience at first, but just think of all the money your saving by not having a TV tech come out to your house and you'll be fine!
May 31, 2009 | Mitsubishi WS-55807 TV
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
