Question about Canon MultiPASS C555 InkJet Printer
Canon multipass C555 will not recognize new cartridge
"put in cartridge" warning after multiple new cartridges have been tried.
Cleaned contacts to no avail.
Unplugged - replugged printer in attempt to reset-no effect
    Problem Solver:
  • 5 Answers
Their may be dryed out ink in the jets. check for that.
Posted on Sep 10, 2009
I have a Canon MultiPass C555 InkJet Printer for my fax machine in the church office. I don't know how old the machine is. Whenever I receive a fax I cannot read it. I even change the ink and I still...
These machines have an integrated printhead built into the printer. The only way to try to fix this issue is to run the cleaning function anywhere from 3-7 times. First, remove the ink cartridges and depress the sponge side onto a paper towel. If you see ink on the towel, proceed to the next step. If no ink is present, replace the ink cartridges. They can be found for very cheap on this model. Next step, depends on whether or not the machine is hooked up to a computer or is just a stand alone fax machne. If it is not hooked up to a computer, go to the menu, scroll to maintainence and select clean cartridges. You will need to do this multiple times. Continue to do it if you see improvement, until you are satisfied with the print quality. You an also perform the cleaning from a computer. Locate the printer in the printer folder and right click on it. Select properties. At the bottom of that window, select preferences. Then select the maintainence tab, and select clean cartridges. Again, you will need to do this multiple times. Please advise if you need further help, or if this does not work and you would like info on current fax machines.
Sep 30, 2010 | Canon MultiPASS C555 InkJet Printer
I have a hppsc 2210 that is saying remove and check cartridge which I have done multiple times. I also cleaned the contacts. Nothing helps.
Maybe you should buy a new cartridge. This warning message usually means that one of the contacts on your cartridge has blown and when you put it in, the printer does not recognize it anymore. If that is the case, sadly, the only solution is to buy a new cartridge.
Feb 25, 2010 | HP PSC 2210 All-In-One InkJet Printer
Canon F50 error Wrong Cartidge , now Put in Cartridge
if you ever get this figured out, let me know, my mp730 says the same thing, i had the head cleaned after i got a wrong cartridge error and now i have a put in cartridge error
Jan 26, 2010 | Cannon MULTIPASS C530 Printer
Error "Put in cartridge" Canon mp370 orange led keeps flashing
This is an issue caused when the cartridges entered are not the one which is usually used by the printer. Check the Cartridge make. It can also be caused of Dirty Cartridge contacts. If that is the problem then you have to clean the Cartridge contact and its connecting socket with alcohol. And most importantly, first check are the Cartridges fully inserted ans set in completely.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Printer says "put cartridge in"; cartridge is already in
When that happens, it's because the printhead has gone out. You need to replace it.QY6-0054-000 around $40.00
Jul 24, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
MULTIPASS C555 INKJET ONLY GIVES ME BLANK COPIES
An other method that might also work for you, is to clean the print head with some rubbing alcohol. Even though the cartridge is new, the print head might be in need of cleaning. It works for me 100% of the time no need to mess with drivers.
Jan 04, 2009 | Canon MultiPASS C555 InkJet Printer
CANON C555 - Black & white only?
You could remove the color cartridge altogether, or just select "Print in grey scale" from the printer properties box.
Oct 04, 2008 | Canon MultiPASS C555 InkJet Printer
Replaced Black Ink Cartridge reading empty
Do a printhead alignment. This will let the printer know your cartridges are full. Here is a link for your manual if you want one. If this doesn't fix the problem just add a coment and I'll be glad to come back and help you out. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=8000
Mar 23, 2008 | Canon MultiPASS C555 InkJet Printer
Will not Print Text
Replace print Head/s with new, oand check cost against new printer with warranty and gen new inks probally more economical. Welcome to our Disposable world!!
Oct 19, 2007 | Canon MultiPASS C555 InkJet Printer
Re:Canon Multipass C3500ex
Don, have you unplugged the printer for a few minutes? first the power plug, see if that clears it. If not, unplug it from the computer, reboot the computer, then plug printer back in. If not that,when an ink cartridge is refilled (depending on the model) the printer needs to be tricked into thinking a "new" cartidge is being installed. They make their money from the ink, not as much the printer. You may need to check the owners manual to see if the is the case. I have had to use tape to block off certain contacts, then remove the cartidge and block off another section of contacts, then remove tape all together and re-insert the cartridge.
Jan 27, 2007 | Canon MultiPASS MP370 All-In-One InkJet...
Canon MultiPASS C555 InkJet Printer Logo
163 people viewed this question
old marine
old marine
