Question about Kenmore HE2 Plus Front Load Washer
Do I only add enough soap in the despensor for 1 load or do I fill it and the machine puts the amount needed in?
    Guru:
  • 1,326 Answers
1 load worth at a time. The dispenser should add water to the same area you ad your detergent to. Just fill it as you normally would. 1/2 to 1 cap full then your fabric softner and bleach in the other dispensers (if your machine has them)
Posted on Sep 10, 2009
Downy goes first than soap
I fill the washer with water first
Then open the lid put in the soap
3/4 cap full,then then 2/3 cap downy
(Both together-bleach as well- if a white load)
I add only to clear water after it fills
Then allow the water to mix the soap
Then add the cloths a few at a time
NEVER put the cloths in & add soap
on them with no water or use the silly
places on the top they say to add stuff
You only add soap etc to plain water &
no cloths & mix first,then cloths go in
Common Sense as to what is taking place
The part about the softener was just silly
It is in the water mixed with soap etc & all goes out
at one time
It is a one step deal
Water,Soap,Downy,then Cloths your done
Nov 04, 2014 | Samsung WF337AA Front Load Washer
Soap
How much HE detergent is used can vary from household to household, depending on such factors as water softness level, soil level of clothing, load size, etc. Because excessive suds can cause build up in the machine, leading to decreased cleaning performance, odor and damage to parts, reduce the amount of detergent if sudsing occurs. How do you know when you have gotten all the soap out? Try extra rinse and make use of custom program to perform additional rinse.
Sep 09, 2007 | LG WM-2277HW Front Load Washer
I put dishwashing detergent in my machine. I only had a small amount that I knew wouldn't be enough to complete a load. So, I added dishwashing soap to the detergent cup. Now, the dishwasher is...
Manually set it to drain... then turn it back on and let it fill....then when it goes to start drain it manually again...do this a few times to get the dish soap out of the dishwasher...
heatman101
Mar 17, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I just bought a washer and dryer that were used and the previous owner was a smoker. Now all my clothes smell like smoke. Any advice the get the smell out of the machine?
Hello, W/D here.
For a single odor, I would recommend a neutralizing sequence. Use one box of baking soda. Fill the soap dispenser as you would with powdered soap, and pour the remainder into the wash tub. Fill the fabric softener and bleach dispenser cups with an odor remover such as Odor-Cide or Febreze. Add 1/2 the normal amount of detergent for a normal load directly into the tub. Run the washer on the hottest, longest cycle available, with the longest, hottest rinse cycle available (usually this is the sanitary cycle). When the cycle has finished, run another sanitary cycle with 2 cups of bleach in the tub, fill the soap dispenser, bleach dispenser and the softener dispenser with bleach also.
After this cycle runs, run another, normal cycle with white vinegar in the tub and dispensers. This can be a normal cycle.
After all of these cycles, one last regular cycle with about 1/2 the normal amount of detergent in the dispenser should get all of the smell neutralized in the machine.
Best regards, Woobie ‰ Dog Please take a momentto rate our solutions so that we may improve in helping others. Thanks.
Feb 24, 2011 | Washing Machines
Does not fill with water? power is on , filters
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load
Dec 06, 2010 | Siemens WFXD5200UC Front Load Washer
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
My front loader doesn't use enough water.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
370 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
