Question about Olympus Stylus 710 Digital Camera
When I turn my camera on it makes funny noises and tries to open up but then closes right away it does this a few times then shuts and the screen turns blue and says D:?????? D:?????
    President:
  • 2,761 Answers
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
Testimonial: "I really appreciate your help, I will give those a try. Thank you!!"
Is there any way I can get my camera back to normal! I turned it on and it said "focus error". When I shut it off to see if it would start over correctly it would not close the lens. I turned...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Nov 26, 2010 | Cameras
My camera lens won't go in and makes a funny noise everytime you try to turn it on. what's wrong?
my camera fell and tried to get the lens inn and now makes a funny noise and does not open
Jun 25, 2010 | Olympus FE-20 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
THE LENS OPENS AND CLOSES QUICKLY DOES NOT LET ME TAKE PICTURES EXS880
Two possible solutions:
1: Lens Error----If the camera powers on and then beeps a few times and then powers right back off.
Same as above but might also say "lens error" before shutting off.
2: Wrong size memory card --------The EXS880 can take up to a 1 gb memory card right out of the box. If you try to use a memory card larger than that you will have to see if there is a firmware upgrade available. Also Casio only recommends 3 brands of memory cards, they are Toshiba, Panasonic and Sandisc. Using any other kind can make your camera act funny.
If it is a lens error the only way to correct that is to send it into repairs. I would first make sure you are using the correct memory card. If you are then you have no choice but to send in and have it fixed.
Sep 12, 2008 | Casio Exilim EX-S880 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Cannot reset camera
I was having the exact same problem. The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Dec 12, 2007 | HP Photosmart R725 Digital Camera
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 710 Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
