Question about Garden
The fan in my electric broom blower shattered........repair, replacements............... it is a cordless broom, CS100 type 1 12 v dc The plastic fan inside the plower shattered and it no longer blows....i really need it and love it as i have arthritis in my hands, it beats a broom for all the outside areas.
  • 388 Answers
You can order the fan (part # 90504254) from either of these websites:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CS100_TYPE_1/ or
http://www.ereplacementparts.com/black-and-decker-cs100-volt-cordless-broom-hard-surface-sweeper-parts-c-4167_9502_9517.html#review_2236
However, the price is close to $50 for the part. Depending on ho wmuch you paid for the blower it may just be cheaper to buy a new one.
Posted on Sep 11, 2009
The Impeller fan does not have a part number, the service department said if it is whith in the one year warrenty they will replace it. the part #90504254 is basicly the whole unit with out the tubes and charging base.
they said:
You can also consider taking the sweeper in to one of our service centers for a warranty determination as well. I've listed the closest location below for you.
You can also order the part that you are needing as well. The part number for the blower assembly is 90504254. I've listed our options for ordering parts below. Please let me know if there is anything else we can assist you with. Thank you.
DEWALT FACTORY SERVICE #145
2841 SOUTHAMPTON ROAD
PHILADELPHIA, PA 19154
215-856-7071
There are 3 ways to order parts for your product.
• Factory owned authorized service centers
• Teleservices Department
• ServiceNet.
To order through a service center, A complete list of our service centers can be found by using our Service Center Locator. To order through our Teleservices department, you can contact them at 888-678-7278, Monday - Friday 8:00 A.M. - 4:30 P.M. Eastern time to check on price and availability. Sorry, delivery to addresses outside of the US is not available at this time. Parts for older or obsolete equipment may not be available on-line. Please contact a service center for availability. To order parts on-line. Please visit, ServiceNet, your one stop shop for all of your GenuineBlack & Decker parts. Inside ServiceNet you will find searchable parts diagrams to our entire current tool catalog. Sorry, delivery to addresses outside of the US is not available at this time. Parts for older or obsolete equipment may not be available on-line. Please contact a service center for availability
Posted on Sep 09, 2010
Blower motor resistor
Locate the blower motor and look around the outside and close to the motor for a 2-by-3-inch plate held on by two or four small screws. There will be an electrical connector plugged into it with five or six wires, depending on the vehicle type and heating and air conditioning type of control panel.
Test the resistor before replacing it. It is always recommended to test any electronic unit before replacing because there are a multitude of things that could cause the same symptoms. It only takes a few minutes and can qualify the assumption that a part is bad. It will save money to replace or repair the right part the first time.
Check the speeds by turning the fan conrol to all positions. Take note which fan speeds work and which speeds do not work. If the fan works only on one speed the blower motor resistor is very likely bad.
Check the fuses if the fan speeds do not work. The fuses for the interior heating and air conditioning fan are usually under the hood in the fuse and relay center. If the fuse looks good, then take it out and turn the ignition key on and use the volt meter set at 20 volts DC. Check to make sure that there is voltage to the fuse. If not, check for an open circuit to the fuse.
Check the relay to determine if there is power at the fuse. The relay should have two of the four terminals showing power. With the key on and the fan turned on, remove the relay and put it back in, listening for it to click. If it does not click, then replace the relay.
Check the voltage at the electrical connector on the blower motor resistor to see if the fuse and relay are good. Make sure that power is present at the connector with the key on and the fan switch on. There should be power at two terminals of the blower motor resistor. If only one terminal has power, replace the resistor. If two terminals have power, replace the blower motor itself. Remove the screws and unplug the connector to remove the blower motor resistor. Put the new one in its place by screwing it back in and plugging in the wiring connector.
Honda Parts.
May 28, 2012 | 2003 Ford Explorer
Trying to register my cordless sweeper but cannot find a place to click on.
http://www.blackanddecker.com/Default.aspx
Click the above link.At the top right hand side of the page you will see the register a product button.Just click that and follow the prompts.
Thank you for using Fix Ya.
Jun 03, 2011 | Black & Decker 12v Cordless Electric Broom...
B&D 12V cordless broom wont charge
if you are able to open from rear end black cover with 4-5 screws ,pull out battery disconect from lugs and you can buy new battery from AMAZON. as my experience ACE COMP. SOLUTIONS
are really good vendor and their customer service is excellent.
you may need UB1250,12V,5amp BATTERY. JUST CHECK WITH OLD BATTERY.
Nov 07, 2010 | Black & Decker 12v Cordless Electric Broom...
My home lite yard broom blower has a vibration at hi rpm
I'm not sure if I have an answer, but I had one that had a broken impeller on the pick-up fan. You can check this by removing the shroud in front of the pick-up fan on the bottom of the blower and check that all of the impeller's are the same size.
Jun 22, 2009 | Homelite 'Yard Broom' Leaf Blower
Dodge Dakota 1997 heater blower failure
It's located right at the bottom of the dash all the way at the far right of the passenger seat. 3 bolts and an ungodly tight clip on the wires are all that hold it in place
Dec 10, 2008 | 1997 Dodge Dakota
Garden Logo
248 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
